Thread: Dimension Anchor Bolt Holes in Baseplate
    April 22, 2017
    65
    01:35 AM
    I've been out of Revit for the past 6 months, so I'm a bit rusty.
    I started a new job three weeks ago, and I'm using new functions within Revit. I used to work with a lot of in place masses and adaptive components for cladding design, and my Revit workflow wasn't conventional, so "normal" Revit is a bit different from what I'm used to.
    Anyway. I'm attempting to dimension my anchor bolt holes in a base plate for a column. Revit won't allow me to even select the holes in the base plate.
    Does anyone know if this is possible, without the use of a dynamo script?
    Thanks!
    3,125
    10:35 PM
    Posting the family would help...as you know families vary a bit
    Sometimes holes are voids, other times they are a circle inside the sketch of the overall baseplate boundary. In other words how the hole is created can impact whether it is there for you to apply a dimension or not. You could ignore the hole and make sure you've got reference planes at the center of where they are so you can dimension that, for distance. If you want a diameter dimension to see it...then the same thing applies, how is the hole made in the family?
    April 22, 2017
    65
    01:35 AM
    I would post include how the base plate was created, but I don’t know how they were lol. Like I said, Structure is new to me. Anyway, I used a reference plane. Offset the distance to the center of the holes and dimensioned to the planes.
    August 2, 2019
    06:35 AM
    Greetings, i am fully agree with you in this modification but plans for next occasations are also primary.
    890
    04:35 PM
    Select the baseplate and bolts and column etc and use the command "create an assembly" - give it a name like UC250+Baseplate
    Then in your project browser scroll down to assemblies and find the newly created assembly.
    Create the views you want by right clicking in the project browser on the assembly and "create views"
    In one of these views you will be able to dimension your base plate.
    This functionality is made for fabrication purposes so I will be surprised if you can not dimension your elements in these views.
  1. Help Needed: Creating Pilaster and Anchor Bolt Plan
    By LordRastlin in forum Structure - General Questions
    Last Post: August 22nd, 2018, 06:08 PM
  2. Structural Column Family - Symbolic Line for Baseplate
    By DD1 in forum Structure - General Questions
    Last Post: November 20th, 2017, 01:17 AM
  3. Anchor Bolt Family Help
    Last Post: August 2nd, 2017, 10:29 PM
  4. pier height anchor bolt height problem
    By Darius in forum Structure - Family Creation
    Last Post: November 20th, 2014, 09:26 PM
