Thread: Truss Framing Visibility
    6,201
    10:16 AM
    I'm working with some trusses (Howe Flat Truss - ootb family) and the framing is showing up in my plan view and it shouldn't be, since it is on the level above my plan (13' from level 1 to level 2.) The view range appears correct and the underlay option is set to None. I'm not seeing the truss element itself, just the bottom chord. Oddly this only occurs when the truss is attached to the roof to create a bow truss. Any ideas?
    edit: if I start a new project (no template) I can't get the behavior to replicate
    Attached Thumbnails Attached Thumbnails Truss-ViewUnderlay.PNG   Truss-ViewRange.PNG
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    285
    09:16 AM
    You can toggle the stick symbol location between top chord and bottom chord in the truss instance properties. Depending on the depth of the truss, visibility could be impacted by view range.
    6,201
    10:16 AM
    Turning off the 'Show Pre-Cut In Plan' box in the framing family did the trick, but I'm at a loss as to why... I'll look into the chord location too. Thanks
  1. Timber Framing for Revit 2014 Extension: Roof Truss problems.
    Last Post: August 10th, 2015, 02:04 PM
  2. Custom truss/framing trouble
    Last Post: March 4th, 2015, 09:01 PM
  3. Loading a family from Structural, Framing, Truss Systems category?
    By debshaupt in forum Architecture and General Revit Questions
    Last Post: January 31st, 2012, 07:38 PM
  4. Roof Framing - clipped truss
    Last Post: January 4th, 2012, 07:40 PM
  5. Framing Plan/ Visibility Graphics
    By iitdesigner in forum Architecture and General Revit Questions
    Last Post: April 18th, 2011, 01:15 PM
