Thread: Mep - system index runs
    June 14, 2019
    04:42 AM
    Hi i need advice on how to work out the duct length of a system from the fan to the furthest air terminal using dynamo.
    I've not been using dynamo long any advice would be helpful.
    February 22, 2013
    344
    11:42 PM
    Did you know that the native Duct Static Pressure Report does this?
    1,402
    05:42 AM
    Depending on how you want to use this.. you can also do it manually in revit if the report doesnt do what you want.
    Make a parameter called 'Is Index Run' and add it to ducts, pipes, fittings.
    Then select the fan and Tab-select the furthest air terminal to select everything in between. Fill in the parameter for this selection.
    Now if you schedule the ducts per system and filter by Is Index Run you can see the total length and pressure drop of your selected route.
    I use this for water/sprinkler piping to schedule length, resistance, static height/head, volume etc together in one place.
    The next step of using Dynamo to analyse all the possible branches to see which one actually is the max/index route would be more difficult. Probably brute force, make all possible combinations of route selections and calculate which one is max pressure.
    February 22, 2013
    344
    11:42 PM
    ^ I've done this exact thing.
    June 14, 2019
    04:42 AM
    i didn't know that was possible thank you.
    however i am based in the uk where we don't use ashrae tables that revits inbuilt system work against, so i was kind of looking for a work around via dynamo. but i'm getting the impression that there are simpler methods than going through dynamo.
  1. Stairs Constructions - Landings not the same as runs
    By BLothian in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2018, 08:10 AM
  2. Stair: Runs: Extend Below Riser Base not working
    Last Post: June 28th, 2017, 09:28 PM
  3. two runs of stairs join not working
    By srwsl in forum Architecture and General Revit Questions
    Last Post: May 5th, 2014, 06:28 AM
  4. MEP runs slow?
    Last Post: July 3rd, 2012, 09:53 PM
  5. Up and down stair runs in one sketch?
    By HenryD in forum Architecture and General Revit Questions
    Last Post: October 28th, 2011, 03:25 PM
