Thread: Curtain Wall Interference Check Problem
    May 16, 2019
    05:56 PM
    Hi all,
    I have a problem when I try to create a curtain Wall system. First I used curtain Wall type and then add grids and mullions but when I do interference check, I got lots of warnings as you can see from the screenshots. I have already tried changing the mullion types and dimensions but did not work. Are these warnings reasonable to ignore if they are not what might be the possible solutions? Thanks in advance.
Name:	Ekran Alıntısı.PNG
ID:	36646Click image for larger version.
Name:	Ekran Alıntısı.PNG1.PNG
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    09:56 AM
    Well...you do have one wall halfway through the adjacent wall. Disallow join for the wall and stop it at the edge of the adjacent wall.
    Member scourdx's Avatar
    July 4, 2013
    57
    09:56 AM
    Do you have duplicate curtainwall ontop of each other? Try deleting one of them and see if you have another one on top.
    April 12, 2019
    12
    05:56 PM
    i have the same problem with the mullions. Even if i try the other curtain wall type, it gives the same interference check problem with the mullions(the same with the owner of the post). is there any way to fix it or should i just skip them
  1. Interference Check by element
    By andyrh1982 in forum MEP - General
    Last Post: October 23rd, 2018, 08:17 AM
  2. Interference Check
    By andyrh1982 in forum Architecture and General Revit Questions
    Last Post: November 21st, 2016, 01:42 PM
  3. Interference Check Help
    By waikikigirl in forum MEP - General
    Last Post: October 16th, 2015, 06:22 AM
  4. Interference check
    By fifthtexas in forum MEP - General
    Last Post: August 28th, 2015, 03:38 PM
  5. Problem with adding custom curtain wall panels to curved curtain wall.
    By aktaylorh in forum Architecture and General Revit Questions
    Last Post: November 20th, 2013, 06:16 PM
