Thread: Panel schedule - default text in space and spare
    August 29, 2015
    105
    09:50 PM
    Is there a way to make a default font and/or text in spaces and spares in a panel schedule?
    I attached a picture, where i tried to type somthing in electrical settings, but it did not work.
    Attached Thumbnails Attached Thumbnails 2019-05-15 08_46_20-Autodesk Revit 2019 - [centralredovisningstest.rvt - Sheet_ Central1 - Sched.png
    August 29, 2015
    105
    09:50 PM
    I solved it. The problem was that i did not used "Load name". When i changed to "Load name" as parameter it works.
    August 29, 2015
    105
    09:50 PM
    Cells are showing -- where the spare or space don't have value/parameter. Is it possible to make it show something else? the best would be if they show nothing.
  1. Create a dimension style with a default text suffix
    By John_C in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2014, 02:33 AM
  2. Altering the default text of the Color Fill Legend
    Last Post: December 15th, 2013, 06:11 PM
  3. Cannot assign Space or Spare to empty circuit?
    By tzframpton in forum MEP - General
    Last Post: November 15th, 2013, 03:31 PM
  4. Space tag text color
    By chompi0n in forum MEP - Family Creation
    Last Post: October 11th, 2013, 11:11 PM
  5. Curtainwall default panel when set to 'none'
    By Daniel Friesen in forum Architecture and General Revit Questions
    Last Post: September 29th, 2011, 02:13 AM
