Thread: Footing not joining properly
    Member EarthRevi's Avatar
    August 13, 2018
    82
    12:32 AM
    I modeled a foundation wall with variouse footing depths and sizes. The building foot print steps several times around the perimeter. When I finished modeling, it looked really sloppy because it didn't want to join cleanly because of different sizes and depths. I had overlap on the end of the footing walls, which was not what I wanted. Is there a way to adjust the footing appearance?
    Member Darius's Avatar
    May 6, 2013
    491
    12:32 AM
    the footings have there on grip handle on it you can adjust the ends that way
    December 11, 2010
    Astana
    147
    10:32 AM
    Could you attach 3d screenshots?
    879
    02:32 PM
    Rather than try to use loadable families, that as you see will not play so well together in certain conditions, just use "in-situ" components.
    Model them in place, you can create multiple extrusions in the one "in-place" model with differring heights and shapes (and even materials if you wish)
    Once you finish the in place model for multiple footings that interact, revit will work out how to join them for you...it works really nicely for stepped foundations like this
    April 14, 2014
    68
    12:32 AM
    Also with wall footings being buggy like this, you can model a void extrusion in-place and cut the offending ends off.
  1. Top of footing tag
    By secondguesser in forum Structure - General Questions
    Last Post: June 20th, 2017, 07:12 PM
  2. footing familes
    By Darius in forum Structure - Family Creation
    Last Post: June 24th, 2015, 07:54 AM
  3. Stair not joining first floor slab properly
    By azsaqib in forum Structure - General Questions
    Last Post: December 14th, 2013, 11:16 AM
  4. Top of Footing
    Last Post: July 20th, 2012, 09:34 AM
  5. Stepped footing not joining with Wall footing
    By AHutchinson in forum Structure - Family Creation
    Last Post: February 14th, 2012, 06:52 PM
