Thread: Nested family doesn't show types in host family
    March 22, 2019
    11:43 AM
    Hi all,
    I created a detail item family for wood siding with three three different types. Once I load the family into the host family and try to change the type of the nested family it keep showing the same type, even though the properties palette shows the three types are loaded in the host family. The host family is a line-based family. Not sure if this has anything to do with the issue.
    I attached the file.
    Thanks a lot
    3,175
    02:43 PM
    The Width parameter in the nested family should be type, not instance.
    2,665
    04:43 AM
    Alf is correct, needs to be type parameter.
    It's kind of counter-intuitive at first as the length parameter in the line based family is instance. Profile families work the same way. Type not instance parameters if you want access to them through the host family.
    I've also recently learnt that you can't host a shared detail component in a 3D family.
    3,175
    02:43 PM
    Quote Originally Posted by antjicar View Post
    H... The host family is a line-based family. ...
    Instead of nesting the detail item family into a line-based family to make an array, you could load the detail item family into a project directly. Then, use the Repeated Detail Component tool, and create different types, one for each of the types.
    March 22, 2019
    11:43 AM
    Thank you gays!
    This forum is of a great help. I love it
  1. Connector doesn't follow nested family
    By evan.dodds in forum MEP - Family Creation
    Last Post: February 23rd, 2018, 01:51 AM
  2. Cut a complex host family with a nested family?
    By Rex Wave in forum Architecture - Family Creation
    Last Post: July 24th, 2017, 01:03 PM
  3. Material by host - nested family?
    By bricklayer in forum Architecture - Family Creation
    Last Post: April 20th, 2015, 09:46 PM
  4. Replace Nested Family with Instance in the Host
    By luke.johnson in forum Architecture and General Revit Questions
    Last Post: April 1st, 2015, 06:02 AM
