Thread: Detail item nested family
    March 22, 2019
    12:31 PM
    Hi all,
    I'd like to create a detail component with nested families and be able to tag these families from the host family. To do so, I understand that the nested family should have checked the parameter "shared". The problem comes when trying to map the nested family's dimensions to the host family's dimension. I get a warning message stating that" shared family types cannot have properties driven by parameters of the host family." I know that this was possible in earlier versions of Revit.
    Does anyone know a way to go around this?
    Thanks.
    10,530
    02:31 PM
    It was not possible in earlier versions of Revit, you are mistaken.
    Either the family wasnt Shared (which lets you do it), or you were mapping instance parameters (which lets you even if they are shared).
    So, make the parameters instance, and you can map them.
    2,665
    05:31 AM
    I was literally reminded of this yesterday when replacing some older unshared door panels with new and improved shared panels. Lol.
    It was a material parameter throwing that warning that needed to be changed to instance.
  1. Detail Item Family Label Param
    By ecraider in forum Architecture and General Revit Questions
    Last Post: March 5th, 2015, 02:04 AM
  2. Detail Item Family
    By ecraider in forum Architecture - Family Creation
    Last Post: January 6th, 2015, 06:11 PM
  3. Replies: 5
    Last Post: April 2nd, 2014, 07:59 PM
  4. Detail Item Not Flexing in Family
    By Revitista in forum Architecture - Family Creation
    Last Post: March 19th, 2014, 01:17 AM
  5. Movable Label Annotation in a Detail Item Family
    By SamHenderson27 in forum Structure - Family Creation
    Last Post: March 1st, 2014, 05:47 PM
