Thread: Can't cut with Void
    3,068
    02:39 PM
    Can't cut with Void
    I'm trying to cut an extrusion (created in Plan & extruded up) with a Void (created in Elevation & extruded back)
    When I use the Cut Geometry tool, pick the solid and then the void, I get an error: "Can't keep elements Joined"
    Expanding the error message lists only the Void.
    So what can't it keep joined with?
    If I pick Unjoin Elements from the error dialog, I lose my solid completely.
    Wellington, New Zealand
    667
    08:39 AM
    I reckon its where your void hits the edge of the solid: it looks like its a coincident point, which Ive had problems before with. If you change your solid extrusion so it continues further up into the void before you cut it, it might work?
    3,068
    02:39 PM
    Good call, Alex!
    That was, indeed the problem.
    I did not know you couldn't do that.
    Thanks!
  1. Revit Window family:Can only select the 2nd void, when the 1st void has been deleted.
    By theoryshaw in forum Architecture and General Revit Questions
    Last Post: February 7th, 2019, 09:35 PM
  2. Mass Cut With Void
    By Shields08 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 1st, 2016, 03:33 PM
  3. Void form not creating void.
    By mikey1073 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 02:13 PM
  4. Void visibliity
    Last Post: July 9th, 2012, 10:40 PM
  5. Beam and void
    By jbenoit44 in forum Structure - General Questions
    Last Post: March 19th, 2011, 03:58 PM
