Results 1 to 10 of 11
Thread: Gutter end caps
    July 10, 2015
    Boise, Idaho
    738
    01:27 PM
    Gutter end caps
    I've been tasked with finding a better solution to putting end caps on gutters. Any advice other than model in place?
    Moderator mark b's Avatar
    NSW Australia
    1,431
    06:27 AM
    Quote Originally Posted by DavidLarson View Post
    Copy your gutter profile then edit it to make it a second "solid" profile.
    Load in and make a new gutter "End Cap"
    Place gutter then place a second gutter (end cap) over top of it.
    Select "end cap gutter" then use drag dots and drag to end of gutter, you will get temp. dimensions to help you if needed.
    Then use "Join Geometry" on both gutters.
    Not an ideal work around but works.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    363
    08:27 AM
    We are using a Line based Family, that has End Caps & Gutter Brackets all-in-one
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    209
    07:27 PM
    I also use a linebased generic familie with the gutter and endcap in 1 family and it works very nice.
    NSW Australia
    1,431
    06:27 AM
    Quote Originally Posted by mjajansen View Post
    How does this work with internal and external corners ?
    I can see how it would work with straight runs but not when it involves corners...
    April 12, 2011
    Chicago, IL
    535
    02:27 PM
    I've used this approach too, but I'll add one extra step that might help. When editing the roof sketch, split the boundary 1/2" or whatever dimension you want from the ends. That way when you place your gutters they'll follow the boundary line segments and you can just create the solid gutter on the end piece. No dragging or eyeballing required.
    June 21, 2012
    Tours, France
    1,044
    09:27 PM
    I've just tested the workaround you've proposed here and I must say that it works perfect for me!! regards
    June 21, 2012
    Tours, France
    1,044
    09:27 PM
    Quote Originally Posted by chris.macko View Post
    Sweet!! I'll add your extra step to my personal workarounds!! bets regards
    Member FBlome's Avatar
    Menlo Park, California
    96
    12:27 PM
    Long ago I choose to hack the solution, and used a gutter profile with a top, ie completely solid/closed. Result was no end caps necessary, and gutters in roof plan looked simple with a single line. Sections not so good looking but at 1/4" scale, nobody has ever noticed nor complained..... Larger scale sections get overlayed with detail anyways, with my workflow.
    December 25, 2011
    The Netherlands
    209
    07:27 PM
    I got 2 families, 1 with endcaps and 1 where you can adjust the corners to 45 degree.
    And if you are better with families than me you can give the endcap a parameter so you can turn it on and off, so you only need 1 family.
  1. AHK Auto Caps Lock script
    By rkitect in forum Tutorials, Tips & Tricks
    Last Post: April 24th, 2014, 09:16 PM
  2. Looking for Suggestions - Column Caps/Soffits
    By TRWhitehead in forum Structure - Family Creation
    Last Post: September 10th, 2013, 02:53 PM
  3. Pipe End Caps Only Slope if added AFTER
    By narlee in forum MEP - General
    Last Post: July 26th, 2013, 10:23 AM
  4. Pile Caps Acting Up
    By RevitNinja in forum Structure - Family Creation
    Last Post: December 19th, 2011, 09:01 PM
