Thread: Need help with Polycurve.byjoinedcurves
    February 11, 2019
    5
    04:35 AM
    Hi everyone,
    I am a newbie in Dynamo. I have a problem with using the poly curve by joined curves. Whenever I run the script with curve points with start and end point to make a curve it gives me an error saying "Curve join produced more than one wire in Polycurve" I have attached an image of what I am doing if you need further information please let me know. Thank you in Advance
    April 18, 2018
    Lyon
    05:35 AM
    If you ask me, the nodes I draw on don't do you any good. Because the existing "Surface" is first exploded and then reproduced without a change. It slows your.
    I don't know what caused the error, but under these circumstances it's not possible to generate the same scenario.
  1. Need help with Polycurve by joined curves
    By Minsc in forum Dynamo BIM
    Last Post: February 7th, 2017, 06:56 PM
