Thread: Running script creates "Dynamo" and "Dynamo Error" material
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,474
    10:34 PM
    A coworker and myself are both using (different) scripts in Revit 2019 in Dynamo 2. We just noticed that two materials are being created "Dynamo" and "Dynamo Error" when scripts are run. Any idea what could be causing the materials to be created or how to prevent it? One script is deleting parameters, the other is using material parameters to set other parameters.
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    271
    12:34 AM
    Can you post a screen shot of both of your scripts. I don't think your going to get much help here without it becuase it really could be a lot of things, too many too mention.
    December 31, 2012
    NM, USA
    1,474
    10:34 PM
    This is the smaller of the two scripts, which I created quickly today to work on our project template. The other is far to complex to try to troubleshoot.
    It does use a node by steam nodes, but the other script doesn't, so I don't think that is the issue.
    2,645
    02:34 PM
    Happens to me all the time. You can drop a few extra nodes in yoir scripts to delete the dynamo created materials but I don't really worry about them now as they don't seem to have any asset elements either
    Or you can just purge-unused them.
  1. Replies: 4
    Last Post: August 2nd, 2017, 02:30 PM
    Last Post: April 5th, 2017, 08:45 AM
  3. Replies: 1
    Last Post: August 30th, 2016, 04:00 PM
  4. Replies: 8
    Last Post: March 21st, 2016, 11:53 AM
