Thread: Geometry in family file not showing above a certain elevation
    January 9, 2019
    10
    02:43 PM
    I have an unhosted family for a smoke detector. One of my parameters is MountingHeight. If I make the mounting height anything above 7' 10", the geometry is no longer visible in the plan view of the family. The same thing happens if I load it into a project first. I have tried it with other families and am having the same issue. I have checked the visibility parameters and can't seem to figure it out.
    Coeur d Alene, ID
    4,853
    11:43 AM
    Change the View Range in your family or project.
    January 9, 2019
    10
    02:43 PM
    I did, that isn't the issue. I have hosted families at that elevation that show up fine.
    January 9, 2019
    10
    02:43 PM
    Ah! I got it! The view range in the project was fine but it was the family view range that was off. Thanks!
  1. Topo hatch not showing in just one elevation
    By jgardner in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2017, 08:34 PM
  2. Elevation showing up on sheet but not on plan
    Last Post: January 26th, 2017, 09:29 PM
  3. Floors Geometry Showing Through Walls
    By qutaibah in forum Architecture and General Revit Questions
    Last Post: July 30th, 2013, 11:35 AM
  4. Hiding geometry in an elevation view
    Last Post: December 4th, 2012, 01:15 AM
  5. Geometry in dwg file to large when linking a CAD file.
    By thojohmail in forum Architecture and General Revit Questions
    Last Post: March 29th, 2012, 10:04 AM
