Thread: Hosting device relative to lower split level?
    February 6, 2015
    85
    09:08 AM
    Hi all, I have a linked model with a sort of split level going on, with an elevation created for each level (as per the linked model). However, I'm trying to figure out if there's a way to place my devices relative the higher elevation within the same view.
    So the view itself is created at (for example) "Basement low level", but then part of the basement slopes up to elevation "Basement high level". Because the view was created at the low level, whenever I place my device at the higher level, it ends up underground.
    I can move it up, but I was wondering if there was a way to make devices place relative the other/a specific elevation, and not the view elevation?
    Thanks!
    June 14, 2011
    CT, USA
    599
    05:08 AM
    While placing the device, change the associated level.
    February 6, 2015
    85
    09:08 AM
    Quote Originally Posted by RobDraw View Post
    Thanks for the reply. Well that's what I was hoping to do, but I can't seem to find an option for that when placing the device? For example, I'm placing a receptacle (so an electrical fixture), but don't see an option for associated level? The only thing I see is "Schedule Level" in the properties, but that doesn't do what I'm hoping.
    Is it in front of me and I'm just missing it?
    June 14, 2011
    CT, USA
    599
    05:08 AM
    Sorry, I was focused on unhosted families. In that case, yes, you would use the scheduled level. I just tried it and it worked as expected. Make sure to set the elevation correctly after setting the schedule level.
  1. Top of Foundation tags ... absolute/ relative to sea level?
    Last Post: July 5th, 2017, 02:37 PM
  2. Replies: 2
    Last Post: March 16th, 2016, 05:01 PM
  3. split the walls per level
    By nod684 in forum Architecture and General Revit Questions
    Last Post: February 6th, 2016, 01:14 AM
  4. Query level to find out what its hosting
    Last Post: January 23rd, 2013, 04:44 PM
  5. Windows from upper level showing up in lower level
    Last Post: January 10th, 2013, 01:18 PM
