Results 1 to 10 of 10
Thread: lisp
    January 7, 2019
    07:05 AM
    lisp
    Does REVIT have any language utilities like LISP?
    June 21, 2012
    Tours, France
    1,043
    09:05 AM
    Quote Originally Posted by meihome View Post
    Well LISP NO, that is more for AutoCAD, in Revit you can work with DYNAMO which allows you to create automations for several tasks!
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    209
    07:05 AM
    There is also the option to use PyRevit with Python or just use the API directly with C#
    June 21, 2012
    Tours, France
    1,043
    09:05 AM
    Quote Originally Posted by mjajansen View Post
    There is also the option to use .... Python or just use the API directly with C#
    Yes, but on the other hand you need to have some programming knowledge to do so!!
    Coeur d Alene, ID
    4,852
    12:05 AM
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,534
    12:05 AM
    Quote Originally Posted by Andres Franco View Post
    not any different with LISP or VLISP (lost in stupid parentheses)
    3,071
    02:05 AM
    I love writing VB Macros in Excel!
    Now, if Revit only had a Macro Recorder so I could learn how to write macros in Revit....
    Coeur d Alene, ID
    4,852
    12:05 AM
    Isn't that what a Journal file is?
    3,071
    02:05 AM
    Nope.
    The Journal file is just a log of everything Revit did & the commands (icons) that you picked. It's basically a debugging tool.
    ' E 03-Jan-2019 15:51:16.258; 0:<
    Jrn.AppButtonEvent 0 , "Application Menu is closing"
    'E 03-Jan-2019 15:51:16.370; 0:<
    Jrn.MouseMove 0 , 236 , 112
    Jrn.Command "Ribbon" , " , ID_REVIT_SAVE_AS_FAMILY"
    The Excel Macro Recorder writes the VB code for you.
    that's how I learned, not only Excel Macros, but pretty much how to code in VB.
    Turn on the Recorder, do what you want in Excel, turn off the Recorder & just like magic, you have executable VB code written
    Sub Macro3()
    ' Macro3 Macro
    Range("A127:O127").Select
    Application.CutCopyMode = False
    ActiveCell.FormulaR1C1 = "=SUM(R[-13]C[14],R[-1]C[14])"
    End Sub
    6,233
    03:05 AM
    Nope.
    Holy **** that's awesome!! I didn't know it would do that!
