Thread: <Yes/No> control <Text> or <Number>
    Junior Member Vester85's Avatar
    January 3, 2017
    12
    08:49 PM
    Hi everyone.
    I can seem to figure this one out...
    Im looking for a formula to control Text-Parameter or Number-parameter by a Yes/No-Parameter
    My best way to describe it, is by a failed if statement
    In a text-parameter formula;
    =IF( [Yes/No] = 1<2, "Text 1", "Text 2" )
    < IF [Yes/No] = True, Then "Text 1", Else "Text 2" >
    In a Number-parameter formula;
    =IF( [Yes/No] = 1>2, "0", "1" )
    < IF [Yes/No] = False, Then "0", Else "1" >
    How can i make this work?
    Sendt fra min SM-G935F med Tapatalk
    1,380
    09:49 PM
    For text
    Make a yes/no parameter (in my example it is test01)
    Make a text parameter (in my example it is test02)
    in test02 place this formula if(test01, "yes", "no")
    For number
    Make a number parameter (in my example it is test02)
    in test02 place this formula if(test01, 0, 1)
    No need for fancy IF parameters when working with yes/no
    January 3, 2017
    12
    08:49 PM
    Thank you for your answer.. I'll try that..
    Thats very simple indeed...
    2,662
    12:49 PM
    Quote Originally Posted by Vester85 View Post
    To clarify - putting quotes around numbers that need to be numbers turns them into strings (i.e. text).
  1. Control model text position using parameters
    By allan120791 in forum Architecture - Family Creation
    Last Post: April 4th, 2017, 10:29 PM
  2. Replies: 20
    Last Post: November 23rd, 2015, 08:31 AM
  3. Room Number / Door Number
    Last Post: July 16th, 2014, 11:19 AM
  4. Room Number & Space Number
    By LKeyser in forum MEP - General
    Last Post: July 3rd, 2012, 02:48 PM
  5. Text notes visibility control
    Last Post: March 21st, 2012, 04:23 PM
