Thread: Create extrusion with sinuous-line shaped surface
    May 29, 2018
    08:37 PM
    Angry Create extrusion with sinuous-line shaped surface
    Dear all,
    I am trying to create a Revit extrusion with a sinuous-line shaped surface.
    - extrusion should be variable in size (length, width, height)
    - one side shoud have ripples "sinuous-line shaped surface"
    - size of ripples should stay constant only the number of ripples should change when flexing
    I tried to work with
    - line based family
    - profile family
    - sweep with one of the above -> did not work
    - extrusion of one of the above -> did not work
    None lead to the desired result.
    -- Any hints for me --
    cheers
    Michael
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    341
    09:37 PM
    Create a family of 1 desired ripple, not a profile, just a generic model family with 1 off your repeating unit. Make that variable in width, length, height.
    Nest that into another Family (could be line-based if desired, I wouldn't do it personally), make an array of your unit there. ink your parameters to the host family.
    Have a slightly modified version of your ripple family with a void on one end that cuts away part of the ripple length, use that one to fill out any length that is left after all the full ripples are placed.
    May 29, 2018
    08:37 PM
    Thanks Bjorn_K,
    this does the job !!!
    I needed some tries with the nesting (Revit seems sometimes erratic in that).
    But finally it works.
    Thanks Again
    Michael
  1. Possible to create a poly-carbonate luminaire family shaped like a cloud?
    By idame in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 11th, 2019, 02:03 AM
  2. How do I create a Y shaped column?
    By dylanrevitq in forum Architecture and General Revit Questions
    Last Post: January 29th, 2018, 07:35 PM
  3. How to create a sub-region on a topo with no surface?
    By Reneedet in forum Architecture and General Revit Questions
    Last Post: June 20th, 2017, 05:22 PM
  4. Lock plan based extrusion to reference line in section
    By Glenn Arne in forum Architecture - Family Creation
    Last Post: July 8th, 2016, 03:44 PM
  5. Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)
    By Glenn Arne in forum Architecture and General Revit Questions
    Last Post: January 27th, 2016, 10:58 PM
