Results 1 to 10 of 12
Thread: Revision schedule
    October 17, 2018
    68
    09:23 PM
    Revision schedule
    Hello to everyone,
    I was woundering if I can add parameters like the ones that are named "issued by:" and "issued to" shown in the picture "Revision table". By adding this parameters I want to achieve a result that is similar to the table with the name "Revision table Jetsj".
    best regards
    Attached Thumbnails Attached Thumbnails revision table jetsj.JPG   revision table.JPG
    3,046
    04:23 PM
    You can't add anything to a Revision Schedule. What comes Out Of The Box is all you can do.
    You request has been in the Wish List for a long time.
    Go here
    https://forums.autodesk.com/t5/revit.../idi-p/6666487
    to vote up the Revit Idea
    January 19, 2012
    333
    04:23 PM
    Edit the TTLB familiy, select the Rev Schd in the PB, in the Properties Palette select "Fields", add those parameters & adjust the widths where it's placed. Reload it.
    3,046
    04:23 PM
    Quote Originally Posted by cftrevizo View Post
    Except that you can't add any parameters to a Revision Schedule
    My apologies. I guess I read the original post wrong. I thought you wanted to add your own parameters, which you can not do.
    If you just want to add the "Issued by" and "Issued to" fields that are already there, then, yes cftrevizo is correct.
    January 19, 2012
    333
    04:23 PM
    ....those "own parameters" thou, they can be added to the TTLB family as a Label with the parameter tied to the Sheet category with Yes/No parameters for visibility. More work with mgmt of it, but doable that way too, but highly not recommended unless some client/project requirement gives you no other "Easy Button" way (& or if it's a cluster any other way) to do it in a more "automated" way.
    October 17, 2018
    68
    09:23 PM
    What is the TTLB family. I never seen that one, also , by what I understood the parameters that I am going to create are going to appear at the sheet properties menu, is that correct?
    @DaveP, Whta I am in fact trying to create are my own parameters... these cannot be done?
    Coeur d Alene, ID
    4,824
    02:23 PM
    TTLB = TiTLeBlock
    3,046
    04:23 PM
    TTLB = Title Block Family
    And now I have to rescind my apology. Guess I DID read it correctly.
    So I return to my post #2. You cannot add your own parameters to a Revision Schedule.
    (Oops, guess I never hit Send. What MP said)
    January 19, 2012
    333
    04:23 PM
    @PPRATICIO
    You could use "Issued to" & or the "Issued from" parameters & rename the Headers (in the Format Tab of the settings) to read like your custom sample. It's just all/some of the 3 non-kosher Fields you're wanting to use will need to be contained within these 2 parameters. You'd just need to add the vertical lines to the TTLB family to align with the formatting where you have the 2-3 fields being emulated in.
    October 17, 2018
    68
    09:23 PM
    @PPRATICIO
    I changed the name of the "Issued to" and of the "Issued from" to have something that would make me happy. I still can´t understand what you are talking... Using that family, the TTLB family, I can add a new parameter or not?
  1. Revision schedule
    By brane1012 in forum MEP - General
    Last Post: November 27th, 2015, 05:50 PM
  2. Revision Schedule
    Last Post: August 19th, 2015, 11:53 AM
  3. 2015: Revision Schedule
    Last Post: July 27th, 2015, 04:23 PM
  4. revision clouds in legend views do not generate revision schedule entries
    Last Post: July 1st, 2013, 10:39 PM
  5. Tekeningenlijst/schedule van sheets met revision schedule
    By rijber in forum Nederlands forum
    Last Post: February 2nd, 2013, 01:50 PM
