Thread: Point(s) by Coordinates _array_array_array AYE?
    4,408
    05:46 AM
    Returning to Dynamo after a while, and as ever, I'm stuck - at the simplest things - and most frustrating, I've (apparently) got the answer laid out in front of me HERE, but noooo…
    So simple: I want (for now) the X,Y&Z values of the list (and indexes 3,4&5) brought in from an .xls, DATAEXTRACT'd from a .dwg using AutoCAD (attached) but with either the code block "fix" from above, or my own ghetto-cooked variant on the same, (active in the .dyn attached) the "Points By Coordinate" node refuses to accept (my) array (?) inputs.
    I experimented with lacing, transposed the list again, tried feeding the values direct to the other "family instance by..." nodes in case the one I was working with was wrong, but nothing.
    What am I doing wrong?
    ...I know it's all about lists again. I really do struggle with them.
    6,205
    12:46 AM
    Need to convert your string to a double for the points to work. String.ToNumber will do the trick.
    4,408
    05:46 AM
    GARGH!!! When I thought that might be it I tried similar, ("NumberFromObject" ?) and it didn't work and I got stuck on the thinking it was all about getting the values "aligned" together to "resolve" the array issue.
    Right, first thing tomorrow!
    Cheers Chad.
    6,205
    12:46 AM
    If you hover over the input of the node it will usually tell you what type of data is needed, if that doesn't work you can try hovering over the title. Last ditch would be to right-click the node and click the help button, which brings up the handy dialog on the right of the attached image which provides some pretty helpful information, as well as a link to the Dynamo Dictionary. And if you need to see what type of data is coming from a node, you can use Object.Type and it will output the data type.
  1. Revit survey point when publishing coordinates ?
    By DeanB72 in forum Structure - General Questions
    Last Post: September 27th, 2016, 05:37 PM
  2. Site Setup - Acquire Coordinates vs. Specify Coordinates at a Point
    By Mel in forum Architecture and General Revit Questions
    Last Post: September 7th, 2016, 11:03 PM
  3. Point Clouds and OS coordinates.
    By Archtronics in forum Architecture and General Revit Questions
    Last Post: June 6th, 2014, 07:36 PM
  4. specify coordinates at point
    By mac32bit in forum Architecture and General Revit Questions
    Last Post: November 19th, 2013, 03:15 AM
  5. How to get at specific point coordinates?
    By Xawier in forum Architecture and General Revit Questions
    Last Post: March 29th, 2013, 05:24 PM
