Thread: How can i make the curtain system grid being straight line in elevation?
    April 25, 2011
    Egypt
    752
    01:27 AM
    Hi every one i make tilted wall in revit using --mass in place , after that when i made south elevation the curtain wall is not straight line , all i want is to make it straight line , i used command align to drawn refrence line but not working any idea how to remedy this problem and thanks
    11,017
    08:27 PM
    Are you sure the face of that mass is planar? Curtain Systems to that when its not Planar, they fan out across the face. Otherwise, you can alter the angles in the properties of the system.
    3,291
    08:27 PM
    I think Aaron's diagnosis is correct.
    If you look way up in the upper left corner of your Curtain Wall, it does not line up with the wall behind it. And the gap is wider at the top than the bottom.
    April 25, 2011
    Egypt
    752
    01:27 AM
    thanks for reply , but guys sorry still i can not understand. i do not understand what is planar and still do not know how to remedy this problem?
    11,017
    08:27 PM
    I dont think the face of your mass is *flat* like a sheet of plywood. I think its warped. Warped = Curtain grids dont run parallel, they fan out across the surface.
    April 25, 2011
    Egypt
    752
    01:27 AM
    yeah, i just discovered the problem that the face of curtian wall in elevation is not 100% rectangle. it was tilted so the lines was tilted too, all i did that i fixed this lines to bo rectangle and it now fixed is that what you mean Twiceroadsfool ??
    St. Louis, MO
    1,964
    08:27 PM
    Look at turning off the UV Grids and draw your own model lines and use Intersects--this lets you "project" them onto your warped surface and control the grid lines
    of a Divided Surface, as I recall.
  1. How to make "not straight" grid lines (example inside)
    Last Post: April 20th, 2016, 06:18 AM
  2. Curtain System - Mullions out of line
    By R-Construction in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 10th, 2014, 06:21 PM
  3. Grid Line Text Issue
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: September 15th, 2011, 03:45 AM
  4. Sloped Grid in Elevation
    Last Post: June 13th, 2011, 12:15 PM
