Thread: Unexpected Value Rounding with a Calculation Formula
    6,329
    11:58 PM
    Per the title - I have a formula setup to calculate a height based on a triangle calculation, and the values are randomly popping up with fractions, and then rounding back down to a non-fraction value and I have never seen this before without using a Round() function. Any clues to what is happening?!
    https://www.screencast.com/t/reNsDihtjN
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    08:58 PM
    Your angle settings are set to 2 decimal places....change it to 3 or 4....as 1/256 is .00390625. So it's rounding to 0.
    6,329
    11:58 PM
    so... there seems to be some sort of change in values (or value display) between 2018 & 2019. note that the angles are set to 2 decimal places in both.
    https://www.screencast.com/t/qQca6faLP (18 on the left, 19 on the right)
  1. Incremental Rounding and Unit Conversion Formula Question
    By SuperDave in forum Architecture - Family Creation
    Last Post: July 12th, 2016, 05:47 AM
    Last Post: September 3rd, 2012, 11:45 PM
    Last Post: August 28th, 2012, 01:45 AM
  4. some unexpected things
    By gaby424 in forum Out There
    Last Post: August 24th, 2012, 11:29 AM
    Last Post: August 16th, 2012, 01:45 AM
