Thread: Pipe fitting family on different angles
    Junior Member Bogey1977's Avatar
    July 12, 2018
    Nederland
    32
    10:50 AM
    Hi all,
    I am building my own pipe-fitting family.
    I have set my possible angles (in pipe settings) on 45 and 90 degrees.
    Nog when drawing pipes, the particular elbows are drawn on 90 of 45 degrees, that goes well.
    This needed sizes are drawn from LookupTable.
    But now I want to use 2 more lookuptable with aricle numbers, one table for 90degrees and one table for 45degrees.
    Is it possbile that the family sees on what angle is drawn, so that the article number can be actracted from the right lookuptale?
    3,171
    04:50 AM
    Yes, this is possible. See illustration.
    This is a test I made using the typical elbow family called "Elbow - Welded - Generic.rfa".
    • "Angle" is an instance parameter.
    • "Lookup Table Name" is a text parameter. It was a type parameter but I changed it to instance so that its value could be driven by "Angle" which is and must be an instance parameter.
    • Also, I opened the lookup table file called "Elbow - Welded - Generic.csv" and saved it as "Elbow - Welded - Generic B.csv". This second lookup table file was imported into the family using the Manage Lookup Tables button.
    • After the changes mentioned above, I put the formula into the Lookup Table Name parameter:
      if(Angle = 90░, "Elbow - Welded - Generic", if(Angle = 45░, "Elbow - Welded - Generic B", "Elbow - Welded - Generic"))
  1. Seek help for The bird claw like 3-way pipe fitting family
    By forhksod in forum MEP - Family Creation
    Last Post: December 30th, 2016, 04:18 AM
  2. Piping system as Pipe fitting family-s
    By Karliaau in forum MEP - General
    Last Post: February 17th, 2016, 08:59 PM
  3. Insulation for model in place family (pipe fitting)
    By Ye Win in forum MEP - General
    Last Post: January 28th, 2016, 03:56 AM
  4. Insulation for model in place family (pipe fitting)
    Last Post: January 22nd, 2016, 02:40 AM
  5. Pipe Fitting Junction Family
    By Roberto in forum MEP - General
    Last Post: January 24th, 2012, 01:57 PM
