Thread: Adding an analytical model line to existing stuctural frame
    April 20, 2018
    19
    05:04 AM
    I've got a question regarding a parametric family (structural framing).
    I created parametric family of a frame with trapezoidal web and I'd like to insert there a simple analytical model lines to export it further to a static program, is there a possibility to do it? (below a screen of the family)
    3,153
    01:04 AM
    There are different ways to deal with this. Choose the method that makes more sense for you.
    1) Revit provides analytical lines automatically for columns and beams. But in this case, it won't give you at the same time a vertical line and a horizontal/slanted line automatically. Therefore, you could do this element as two separate families. One that is a column and another one that is a beam. (Not nested). Now you will get the 2 analytical lines automatically, and always related to the start and end points of both column and beam.
    2) It is possible to add the analytical lines "manually". Like this: Component > Model in Place > Generic model > (choose linetype "anatytical lines [projection], set a workplane, draw the analytical line, and create a group with the analytical lines and the family of the frame that you created,
    3) Do this frame as a truss family. This solution will give you automatic analytical lines for both members of the frame and will keep all the dimensions parametric. You just have to select a custom tapered structural member for the vertical piece and a tapered member for the slanted piece. This solution is simple and works well. See illustration for this solution.
  1. Adding an analytical model to a family question
    By rafalactun in forum Structure - General Questions
    Last Post: September 20th, 2018, 11:00 AM
  2. Adding a story to an existing model
    Last Post: January 23rd, 2014, 03:01 PM
  3. Questions about adding "lines" to a work frame model
    By billbe in forum Structure - Interoperability
    Last Post: January 18th, 2012, 02:26 PM
  4. Questions about the about adding "lines" to a work frame model
    Last Post: December 29th, 2011, 02:45 AM
  5. Analytical line for model in place beam...
    By christian0102580 in forum Structure - General Questions
    Last Post: August 12th, 2011, 06:38 AM
