Results 1 to 9 of 9
Thread: Formatting multiple schedules
    January 5, 2018
    Bilbao / Spain
    5
    04:36 AM
    I'm trying to generate some automatic tasks in my company. I'm learning Dynamo as I go and I'm having some troubles with the following:
    I want to format the schedules in a certain way, right now I'm testing with the font type but the idea is to, as soon as I work out the automation, go further.
    The state of the work is as follows
    As you can see in the picture I need to go one by one connecting the schedules to "Schedule Appearance" instance. Is there any way to do it as a batch? Right now i have 31 schedules to format, but we expect to have bigger numbers in future projects.
    Thank you in advance!
    6,205
    12:36 AM
    You can create your code block as a single list instead of a lot of separate items.
    I think you can connect your ElementFilter.ByName directly to the Schedule Appearance node as well (might need to flatten the list) - have you tried that?
    January 5, 2018
    Bilbao / Spain
    5
    04:36 AM
    Hi cellophane
    I have already tried to connect directly from ElementFilter.ByName to Schedule Appearance and the result is "null" and the schedule is not changing
    Also after flattening the list
    6,205
    12:36 AM
    What does changing the lacing on the Schedule Appearance node do?
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    336
    06:36 AM
    The output from your Filter node is a list with lists of views, I'm guessing it has 2 lists, 1 with Schedules that pass, and 1 with those who fail. Get the first list from that list.
    2nd, dump the Code Block and connect the list mentioned above to your Schedule Appearance Node.
    2 things worth mentioning:
    -learn to filter using the FilterByBoolMask, it will teach you what the result of your filter actions actually is, and it has 2 outputs, so you can connect the other nodes straight to the required list.
    -The Schedule.Appearance node is a custom node, depending on which package that is from and which version it just might have problem with your Dynamo Version.
    January 5, 2018
    Bilbao / Spain
    5
    04:36 AM
    After changing it from "shortest" to "longest" is working great!
    Thank you!
    January 5, 2018
    Bilbao / Spain
    5
    04:36 AM
    Hi Bjorn
    After changing the lacing to "longest" I removed the Code Block and is working as well.
    About the FilterByBoolMask, I'm really new with Dynamo, after a quick search whit google I cannot see the point to use it. It looks like you need bigger knowledge to use it and I will research it. Thanks!
    1,403
    06:36 AM
    I found this a useful introduction to how to use some of the functions in Dynamo, including Filter By Boolean Mask . It is one of the most used functions to handle lists so worth understanding.
    https://prezi.com/jqdljnvns9si/utili...tional-design/
    (Thanks to Andreas Diekmann)
    Also you might want to use Get Item at Index and a number slider instead of that crazy OUT list
    January 5, 2018
    Bilbao / Spain
    5
    04:36 AM
    Hi Joseph
    Actually, after changing the lacing to longest I don't need the OUT list, I can go directly from the filtered schedules to the Schedule Appearance node. The OUT list was the only previous way I founded to run the script
    I will research the prezi. Thanks!
  1. Schedules - Formatting (Bold totals!)
    By guitarchitect in forum Tutorials, Tips & Tricks
    Last Post: June 3rd, 2019, 02:38 PM
  2. Conditional Formatting in Schedules using characters instead of cell color?
    Last Post: August 24th, 2017, 06:50 PM
  3. Conditional Formatting Door Schedules
    By d.stairmand in forum Architecture and General Revit Questions
    Last Post: May 13th, 2015, 01:38 AM
  4. Stack Formatting Schedules
    By billiam in forum Architecture and General Revit Questions
    Last Post: January 21st, 2015, 01:49 AM
  5. Formatting Window Schedules
    By Alan Roberts in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2011, 02:03 AM
