Thread: Room calculation point how to put my curtainpanell to the rooms ???
    November 18, 2013
    Germany
    108
    09:24 AM
    Hello,
    How can I schedule my facadeelements from room/to room. I nested a generic Modell with a room calculation Point, but I am unable to list Elements with there order to the room. How it works? Does anyone have an workflow?
    KR
    Andreas
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    381
    11:24 AM
    Several options:
    1. If you really need both From and To Room info, change the category of your panels to Doors, enable Room Calc Point and done. Take care in your Door and Panel Schedules to sort/filter for the right elements at the right time.
    2. If you only need 1, you can indeed nest a GM Family, make sure it's a Shared Nested Family. I like to make an Instance Shared text parameter then ("Panel Number" ) in the GM family, tied to the same parameter in the Panel family. Then number all your panels in the project to sort out which GM belongs to which panel. (Can I suggest Dynamo to number all these panels).
  1. No rooms in door schedule unless door family has Room Calculation Point
    By mgjp in forum Architecture and General Revit Questions
    Last Post: June 12th, 2017, 11:07 PM
  2. Room Calculation Point
    By Mike Adams in forum Architecture - Family Creation
    Last Post: September 14th, 2015, 08:06 AM
  3. Room bounding walls & and room separators. Rooms have no boundaries?
    Last Post: September 26th, 2013, 07:53 PM
  4. What Revit Wants: Revit 2013 - Room Calculation Point
    Last Post: April 1st, 2012, 11:46 PM
  5. Glazing/Room Calculation API
    By mark b in forum Third party Add-Ins, API and R&D
    Last Post: April 12th, 2011, 09:45 PM
