Thread: Warren Truss (height flex problem)
    September 14, 2018
    Rotterdam
    06:11 AM
    I tried to make a truss with a warren configuration, it is made as a 'structural truss family'.
    The diagonals are always spanning 3 meters, I made one array for the diagonal going up, one for the diagonal going down.
    The flexing in width is without a problem (if you keep the parameter for the array above 1).
    Flexing in height is a different story, as soon as you put a diagonal in an array it loses its connection with the bottom chord.
    However, Revit has a 'Howe flat truss' which does exactly that, flexing in width ánd flexing in height although it is an array.
    Does anyone know how they built that family, I can't see any constraints within the array.
    3,153
    01:11 AM
    It is easier to make truss families using the templates provided for that purpose.
    If you want to get an idea how the How Flat Truss is made, you can open that family, go to VG and turn on annotations. You will see all the dimensions and constraints.
    January 12, 2019
    10:11 PM
    I'm a new REVIT user and currently have a subscription to REVIT LT. As the LT version has limited family's, I'd like to know if I can create a pitched wood truss family....? I currently don't have a "Structural Truss" family template with REVIT LT....
  1. Problem With Coping Truss?!
    By sarsonsk in forum Structure - General Questions
    Last Post: August 18th, 2016, 03:14 PM
  2. Room height problem
    By Rvto in forum Architecture and General Revit Questions
    Last Post: April 19th, 2016, 06:56 AM
  3. pier height anchor bolt height problem
    By Darius in forum Structure - Family Creation
    Last Post: November 20th, 2014, 08:26 PM
  4. Model height varies with project floor height
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: April 8th, 2014, 08:51 AM
  5. Roof truss dxf export problem
    By mEANm in forum Architecture and General Revit Questions
    Last Post: April 24th, 2012, 07:48 AM
