Thread: Family parameter problem
    February 7, 2018
    09:53 PM
    Question Family parameter problem
    Hi!
    I have a problem...
    I want to do a family that have a line going from on corner to an other in a rectangel. In middle of this line I want a parameter text that stays 90 degrees against this line. And also the text should be in the middle all the time. you should be able to change the size of the rectangel. see picture
    Thanks for help!
    /Rulf
    1,380
    09:53 PM
    I was going to explain what I did with my family, but that would have been a long bit of text and I'm sure not very clear. So instead I decided to add it to the post. I was asked by a client to make this and it is a bit more complicated than what you are looking for, because they wanted the text to be on the line and not above it, but the idea is similar.
    Basically it is a few nested generic annotations and formula's for the angles
    February 7, 2018
    09:53 PM
    Thanks Solved my problem
  1. select by parameter? curtain wall panels' materials by parameter, by type or family?
    Last Post: January 24th, 2013, 02:20 PM
