Results 1 to 10 of 15
Thread: "Flatten" or "stiffen" parametric family
    July 14, 2016
    85
    08:11 PM
    Hi
    Is there a way to "flatten" (strip out of all parameters and options) the parametric family?
    For example you have a parametric window family that you produced, and that you use to model several buildings. Client does not require you to provide this kind of parametric family (all he needs is a model as-built), and you only did that to speed up your work and save time - therefore you don't want to give it away as a bonus.
    Is there a way to "stiffen" the family, so it stays as inserted in the model and has no further adjustments option?
    Thanks!
    4,415
    09:11 PM
    Export your model to .ifc,.nwc, .dwg or any other transfer format and send them that instead of the .rvt?
    EDIT
    NOTE: I am not advocating you do such a thing.
    July 14, 2016
    85
    08:11 PM
    Unfortunately model has to be *.rvt.
    I guess it has to be manual then. I was just hoping there's a command like that (something like "flatten layers" in photoshop)
    1,377
    10:11 PM
    Quote Originally Posted by paidpal View Post
    So instead of giving them a project (which they payed for) with a bit extra smart families you decide to spend even more time (which you won't get payed for) to strip out all the work you already did effectively undoing the stuff that cause you do speed up the project?
    Does not sound very smart or efficient to me.
    Coeur d Alene, ID
    4,850
    01:11 PM
    I take it you don't share your models with consultants if you are concerned about giving the model to a client?
    July 14, 2016
    85
    08:11 PM
    Depends how you see it. If giving away the complex family means they will be able to produce the models by themselves in the future without my help, maybe indeed it's not time efficient, but at least I'm not shooting myself in the foot. We're not paying for the software licence so we can be a charity (or do we?).
    PS. I dream of a place we we can just get answers to the questions without all that unnecessary judgments and discussions leading nowhere
    1,377
    10:11 PM
    OK, well then let me give you an option how to do it.
    Export to IFC, start a new clean project and import the IFC again.
    PS. I dream of a place where people just don't care that their clients get a bit more information then they payed for without being scared that they will take projects away from you because you have no other added value for them then just those few families.
    2,658
    01:11 PM
    I’m that case... no, you can’t do that easily.
    There, was that helpful?
    July 14, 2016
    85
    08:11 PM
    Thank you, if you want to make it personal, fine. Whatever I produce, it's never "just", just so you know not to measure another's corn by our own bushel.
    July 14, 2016
    85
    08:11 PM
    It was indeed, thanks!
  1. Replies: 2
    Last Post: February 15th, 2016, 07:28 PM
  2. "split surface" and "paint" in nested family
    By marcomella in forum Architecture and General Revit Questions
    Last Post: February 11th, 2015, 07:28 AM
  3. Rebar Diameter symbol "Ø" is Showing as "0" in Revit 2014
    By Shefypattambi in forum Architecture and General Revit Questions
    Last Post: July 14th, 2014, 01:49 PM
