Thread: ceiling tag to read as spot elevation (top or bottom elevation) (2017)
    June 26, 2014
    90
    11:44 AM
    i would like to have a ceiling tag read the way a spot elevation reads the "top elevation" or "bottom elevation" of an element? for instance, in an RCP i would like the ceiling tag to read the underside of the ceiling (gyp.bd.) or "top elevation"
    3,175
    02:44 PM
    Unusual, but possible. You need a custom type parameter to enter the thickness of the ceiling, and a calculated value in the tag, to add the thickness to the offset from level, to get the elevation at the top of the ceiling. Then, create two types of tags, one to show the standard offset from level, and another type to show the top elevation.
  1. Spot Elevation in Family to read level in Project
    By Jwatto in forum MEP - Family Creation
    Last Post: August 16th, 2018, 04:53 PM
  2. bottom/top elevation
    By philsogood in forum MEP - General
    Last Post: April 27th, 2017, 10:17 AM
    Last Post: July 3rd, 2015, 11:50 AM
  4. bottom elevation tag for pipe
    By swapr78 in forum MEP - General
    Last Post: January 15th, 2015, 04:22 AM
