Thread: Pipe flange family with nuts and bolts
    January 3, 2017
    26
    08:27 AM
    Hello dear engineers. I'm working on a hospital project and need to model with LOD 350 in this case looking for Pipe flange family with nuts and bolts automatically creared. I'd appreciate you if anyone can help me with this.
    Regards
    Sent from my SM-N920C using Tapatalk
    1,402
    10:27 AM
    Well you seem to already have an example to start with..
    You should make it as a separate flange family for a single flange, then load it into your pipe fittings.
    Make it parametric so it changes size based on a single pipe diameter parameter, then link this in the pipe fitting to the Nominal Diameter of the fitting.
    For example outside flange diameter = 2x pipe diameter, or whatever the relation is.
    The bolts can be made by modelling one bolt, with a parameter for its position from the centre of the pipe, then rotate with an array. That way you can also link the radius of the bolt circle to the pipe size.
    January 3, 2017
    26
    08:27 AM
    Thank you joseph for answering. Actually i add nuts and bolts manually to flange i mean I've create them and after finishing piping one by one add nuts and bolts to flange. In this case i need a family or guide to create them in parametric way.
    You mean that i select a flange family then open it in edit family and add nuts and bolts there....
    Right?
    1,376
    10:27 AM
    If you add the bolts to your flange family and array them around the center, you can make a parameter that calculates the amount of nuts for the diameter of the flange. Should be doable for sure, will take some time, but you will be able to use that flange for every pipe size.
    January 3, 2017
    26
    08:27 AM
    Thanks Robin. I've tried it but for big sizes i have problem. I mean maybe i don't know how to create correct parameter for them. Exactly i use a flange catalogue for size and number of bolts then create parameters but couldn't get my acceptable result.
    Still have a serious problem with formula part.
  1. Pipe Couplings/Flange Adaptors
    By EC05 in forum MEP - Family Creation
    Last Post: January 17th, 2019, 07:17 PM
  2. Model bolts
    By Procadd in forum Structure - General Questions
    Last Post: December 11th, 2017, 01:39 AM
  3. 3d bolt and nuts in revit family file
    By yap1312 in forum Architecture and General Revit Questions
    Last Post: February 19th, 2017, 07:58 PM
  4. verctical bolts
    By akaplan in forum MEP - General
    Last Post: February 22nd, 2016, 04:15 PM
  5. Replies: 5
    Last Post: June 10th, 2014, 10:00 PM
