Thread: Revit if formula gives message of inconsistent units
    November 16, 2017
    Netherlands
    6
    08:54 PM
    So i am trying to make a if formula of 2 parameters that result in 1 of 3 options of data.
    In this case i try to give my door family a automatic firerating for use in IFC.
    The door has three options, no fireproofing, 30 minutes of fireproofing or 60 minutes of fireproofing.
    this results in 2 yes/no parameters:
    - brandwerendheid_30min
    - brandwerendheid_60min
    with this i try to give the IFC parameter FireRating a formula to automatically apply o, 30 min or 60 min to the parameter.
    For this i use the following formula which should work:
    - if(brandwerendheid_60min, 60 min, (if(brandwerendheid_30min, 30 min, 0)))
    Sadly i always receive the message, inconsistent units.
    if i simplify this formula to the following, i receive the same message:
    - if(brandwerendheid_60min, 60 min, 0)
    - if(brandwerendheid_60min, 60 min, 30 min)
    I used the parameter brandwerendheid_60min also in a different formula, removing this formula didn't change anything.
    If anybody can help pleas let me know.
    Attached Thumbnails Attached Thumbnails vraag over parameters en formulas.PNG
    Kingdom of Denmark
    4,248
    08:54 PM
    The FireRating parameter have to be a Text parameter, and the text in the formula must pň enclosed with quotes (") - See the attached screenshot.
    if(brandwerendheid_60min, "60 min", (if(brandwerendheid_30min, "30 min", "0")))
    November 16, 2017
    Netherlands
    6
    08:54 PM
    That did indeed work as intended.
    Many thanks for the reply!
    1,380
    08:54 PM
    So interesting to see that everybody is doing the same thing for the same families.
    Looks like you are doing some interior doors with all the data in them (fun project !)
    Done those as well a while ago (and again after I wanted more info, and again after I learned more stuff)
    If you are interested to see one of mine send me a message (info@deurloobm.nl) and I'll email it to you, so we can compare notes.
  1. Revit - Inconsistent Units and how to neutralize them.
    Last Post: July 12th, 2019, 02:07 AM
  2. inconsistent units, problem with formula linking too lookup table
    By wackadoodle in forum Architecture and General Revit Questions
    Last Post: July 13th, 2018, 10:52 AM
  3. Inconsistent units - IF statment
    By JKnight in forum Structure - Family Creation
    Last Post: July 25th, 2016, 01:45 AM
  4. Question regarding Inconsistent Units
    By goodrichard_21 in forum MEP - Family Creation
    Last Post: October 6th, 2015, 06:15 AM
  5. Replies: 12
    Last Post: June 4th, 2013, 07:08 PM
