Results 1 to 10 of 15
Thread: Array of Varying Nested Family
    March 5, 2018
    7
    07:03 PM
    I'm trying to model a couple of parametric handrail models.
    I've got two different scenarios where I can't get any constraints to work. The two tasks are slightly different, the first the vertical bars need to change length as they are patterned. The second, the bars need to follow the references as the handrail slope changes.
    I assume this can be done, I just have no training in Revit. Would anyone be so kind as to explain this to me please?
    Thanks in advance,
    Jake
ID:	34345   Click image for larger version.
    Senior Member DavidLarson's Avatar
    July 10, 2015
    Boise, Idaho
    783
    01:03 PM
    Are you making a family or doing it with the handrail tool?
    March 5, 2018
    7
    07:03 PM
    I'm making a family, sorry, I thought I'd put that in there...
    March 5, 2018
    7
    07:03 PM
    Is anyone able to help out on this one? Thanks in advance.
    March 21, 2013
    Phoenix, AZ
    275
    12:03 PM
    The railing tool really is the preferred way to accomplish this, especially the one on the right. If you really need it to be a loadable family (why would you do that to yourself?), I'm sure you could wrangle some workarounds to make it work, but they won't be very straightforward.
    March 5, 2018
    7
    07:03 PM
    Hi Chris, thanks for the reply.
    The fact that it is a handrail isn't really important, I do quite a lot of families in Revit and this is just an example. What I am interested in is why I'm unable to array a nested family with varying lengths and wondered if anyone had a solution. I thought it must be something that people often require when creating custom families.
    4,442
    08:03 PM
    The trick would be to cut the arrayed (same length) child members in the parent family.
    March 5, 2018
    7
    07:03 PM
    Hi Snowyweston, thanks for the input, this is seems to be a solution that could work. I haven't been able to get it to work with nested families though, just in-place solids.
    Another issue is when I add child members by increasing the number of instances of the array, the cut misses the new members. As a workaround you can create the family with as many instances of the array as is practical and anything with less will be fine, but this isn't ideal.
    There surely has to be a proper solution for this?
    Example family attached for reference.
    August 19, 2011
    New Hampshire
    519
    03:03 PM
    Array the space between the members, not the members themselves.
    March 21, 2013
    Phoenix, AZ
    275
    12:03 PM
    Quote Originally Posted by ISOJake View Post
    Sort of, maybe, conditionally.
    Adaptive components should be able to accomplish the type of dynamic behavior you're after, but they come with their own set of limitations, including a steep learning curve. See here: RevitCat: A Dozen Reasons Not to Use Adaptive Components in Revit
    In the traditional family editor, arrays must contain identical items, since you are arraying a group, which must be identical (by definition). You can play with voids, etc, but the voids must be in the same family as the form you're trying to cut, so that limits nesting options. You want to array non-identical items; therefore, you're in the realm of creative workarounds outside of a "proper solution".
  1. Cut a Nested Family (used to create an array) with a Void
    By ndjabiras in forum Architecture - Family Creation
    Last Post: November 30th, 2017, 03:07 PM
  2. Void to cut end off array of nested family - A metal deck roof sheet problem
    By williamturner1 in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2016, 05:20 PM
  3. Angled array nested into roof truss family
    By gioginnelli in forum Architecture - Family Creation
    Last Post: June 26th, 2014, 05:04 PM
  4. Replies: 5
    Last Post: April 2nd, 2014, 07:59 PM
  5. Array nested voids in a family
    By dzatto in forum Architecture - Family Creation
    Last Post: May 25th, 2012, 02:10 AM
