Results 1 to 10 of 11
Thread: Custom Stair Tread & Riser - Concrete Filled Pan
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    08:15 PM
    Has anyone ever created something like this before?
    I know we can create separate profiles for treads/nosings/risers etc... however am I right in thinking that custom profiles for these components can't be parameterised. If so do you end up duplicating profiles and hard coding the sketch sizes to suit the situation? E.g. a stair has a custom riser/tread that is to be used on storeys where the riser height and/or tread length is different.
    1,380
    09:15 PM
    for some reason I am always very tempted to build a stairs as a generic model (or some other category), because I still dislike the stairs tool. Pretty sure that would be the case with your example as well.
    2,665
    05:15 AM
    You can parameterise profiles but only by type, so that means new profile types for each run type. And no, the stair tool won't allow instance based profiles per tread/riser in a single run. So it's 1 profile per stair type. Well, per run type per stair type...smh.
    Dont know the rules of Scotland but down here every step needs to be the same throughout each run anyway.
    December 11, 2013
    464
    08:15 PM
    Hey Elton, I guess what I wrote was a little confusing. In each run, all risers and treads will be constant (like you guys in Oz, we aren't allowed to vary these in a run). What I was meaning is that I have different storey heights in a current project (2550/3600/2850) and I have a common stair which provides access to all of these. If I were to use a custom Tread/Riser/Nosing profile, I'd like to be able to use it on runs for all of these storeys however I'm pretty certain I can't link a custom tread depth parameter in the profile family to the equivalent instance parameter in the stair therefore any variances in risers and treads for the different storeys (I assume) will need different profiles drawn to the size needed.
    2,665
    05:15 AM
    Well, treads work off minimum length and risers maximum height. Without going back and seeing if you mention what Revit release you are using, from 2018 you can adjust level to level sections of multi level stairs individually. I don't know if this will allow unique conditions (within tread/riser parameters) but Paul Aubin has a really great video showing all the ins and outs of these new multi storey features on Lynda.com
    December 11, 2013
    464
    08:15 PM
    I'm using 2018.2 and I've yet to deal with multi-storey stairs. I've just been looking over typical fabricators drawings that I've just received and have noticed that the top tread is actually smaller that the normal tread:
    I think this is precisely a scenario where again the stair tool can't create a run with different length treads AND custom tread profiles.
    I recall a stairs video and handout that Phil Read demonstrated how to create complex stairs using balusters families with nested GM's. Even if that method were to work, it would probably take some time to get set up and accustomed to and I do wonder if perhaps Robin's suggestion of a GM family for the entire stair has some merit
    2,665
    05:15 AM
    For difficult stairs i'm not against MIP except you'll need todeal with the loss of stair category visibility control in plan. You lose all the builtin cutline, dashed overhead, run arrows and tread numbering features.
    If you MIP you can use stair category, component family can't be stair category (although it could be a railing, i've never tried)
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    363
    08:15 AM
    I must be blind, but when I read that drawing, it says "9 risers @ 166.66"?
    That 250/240 measurement is the Stringer vs Floor Beam Set-down isn't it? nothing to do with the treads?
    December 11, 2013
    464
    08:15 PM
    Quote Originally Posted by d.stairmand View Post
    I'm not sure what's confusing but :
    250 is the depth of the stringer
    240 is from FFL to top of PFC
    275 is the going of each tread
    166.66 is the rise of each tread
    February 24, 2011
    Auckland
    363
    08:15 AM
    Agree 100%
  1. Stair Tread Obscuring Stair Path Arrow
    By Manderson in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2019, 08:22 PM
  2. Riser in Stair Landing
    Last Post: June 20th, 2019, 03:58 PM
  3. stair landing/end with riser
    By jillcontest in forum Architecture and General Revit Questions
    Last Post: February 22nd, 2018, 03:45 PM
  4. Stair by Component - Stair tread profile & detail components
    Last Post: October 17th, 2013, 06:26 PM
  5. Revit 2014 - Component stair - If you don't end with riser the last tread is shorter?
    By basilmir in forum Architecture and General Revit Questions
    Last Post: May 20th, 2013, 09:24 PM
