Thread: Rendering a glass bottle or wine glass
    July 3, 2018
    10
    05:04 AM
    Hi all,
    Finding the Revit Rendering engine in 2017 produces great images, struggling however to produce a realistic glass shader for objects the populate my scene.
    They always turn out dark grey, what am i doing wrong?
    What would be a good set of material settings?
    Many thanks all !!
    June 21, 2012
    Tours, France
    1,032
    07:04 AM
    Quote Originally Posted by homerdude View Post
    Hi all,
    Many thanks all !!
    Hi, Can you post your glass settings?
    July 3, 2018
    10
    05:04 AM
    Hi Andres,
    Thanks for replying so soon!
    Here are the settings I'm using
    June 21, 2012
    Tours, France
    1,032
    07:04 AM
    well, all seems to be ok, nevertheless, I've noticed that in the information part the name: Glass_Clear(1), contains a (1) at the end, this happens when you duplicate a material without renaming it, so it may happened that you've already modify the settings for another glass (that without the (1)) at the end and accidentally this modify your new settings, or at least is what I've noticed, It seems too that your color was modify too! you may try to duplicate the "material resource", by hitting the button replace source (see image) or change it for another Glass resource, the last thing may work or at least that will be my first try, hope this can help you, regards
    March 21, 2013
    275
    10:04 PM
    Make sure your Quality settings are High or better. The engine won't render refractive transparency at anything lower.
    4,408
    06:04 AM
    Whilst I've achieved "better" (actually, arguably, the other end of the spectrum where the glass'iness is too indistinct) you're generally advised to move away from using the procedural material asset definitions....
    July 10, 2015
    Boise, Idaho
    716
    11:04 PM
    I put beer in my mugs to be rendered. Even put in parameters to adjust the amount of beer and head is in the mug. Then no matter what, the glass was irrelevant. This was back in '12 when I was learning Revit and doing everything possible to NOT model anything like what the paying jobs had in them. It sure irritated the management but 6 years later they're still wishing to go back to Microsatan so there you go.
  1. Glass Symbols on Glass Elevations
    By kamranmirza in forum Architecture and General Revit Questions
    Last Post: September 4th, 2018, 05:07 AM
  2. Rendering Colored Glass in Revit 2017
    By rteneb in forum Rendering and Gallery
    Last Post: July 17th, 2017, 03:49 PM
  3. Nested Materials not Rendering & Stained Glass
    By cellophane in forum Rendering and Gallery
    Last Post: December 16th, 2014, 07:48 PM
  4. Revit rendering and glass
    By leetecture in forum Rendering and Gallery
    Last Post: September 27th, 2012, 08:49 PM
  5. Problems rendering transparent glass
    By thewrz in forum Rendering and Gallery
    Last Post: February 10th, 2012, 07:00 PM
