Results 1 to 9 of 9
Thread: Line-based edge-picking family?
    July 7, 2017
    Hernando, MS
    522
    03:29 PM
    Is it possible to create a line-based family that is placed by picking a 3D edge in a 3D view, and the host will be that edge and not some horizontal work plane or level? It almost needs to be like a combination face/line hosted family.
    One use would be for things like roof ridge vents, or hip/ridge tiles for a tile roof.
    August 19, 2011
    New Hampshire
    506
    04:29 PM
    If you set your workplane to the surface you're adding the family to, you can draw on that line. I'm fairly sure choosing it as the host is impossible.
    10,518
    03:29 PM
    Line Based Generic Models CAN use Pick Lines, to select an Edge. But the workplane WILL be one of the two faces of the roof, and it will orient it self as such. Only way around that is adaptive components, per (perhaps) a structural framing family. But... yuck, on both counts.
    I just make my Ridge Vents modeled off one plane of the roof (as the LBGM) and they work great.
    July 7, 2017
    Hernando, MS
    522
    03:29 PM
    Yep I noticed that behavior of the tilted ridge vent.
    Another thing I wanted to make was a line-based family for those RainhandleR rain dispersion louvers, which have little brackets every so often, and then 6 louver blades running continuous long the roof. I succeeded in making a railing family that works pretty well, and I can pick my roof fascia trim if I have a level datum in that spot. But I'd rather have an actual family that can be saved and loaded instead of a system family, and picking the edge in 3D is so much easier than trying to draw it in plan or elevation, picking a work plane, blah blah blah, especially when there are many of them around a roof.
    Another thought: what about nesting a line-based family into a face-based family???
    10,518
    03:29 PM
    Doesnt work that way. Besides: A LB family is already a Face Based Family.
    Honestly, i have some LB Louvers, and i dont like them. Id rather completely unhosted or Face Based and stretchable. The User Experience on the Line Based ones isnt that awesome. For Ridge Vents, all day long. Louvers, i wouldnt do it.
    2,660
    06:29 AM
    Agreed regarding louvres. Also, LB families have that habit of auto-joining in line and at corners precisely when you don't want them to - and there's no option to disallow joins like you can with say, walls.
    July 7, 2017
    Hernando, MS
    522
    03:29 PM
    These aren't "louvers" like you normally think of louvers in a wall, they're a gutter replacement product. So they run along the edge of a roof eave/fascia. Instead of a single metal profile like a normal roof gutter, they're small brackets spaced out with 6 little metal strips running along the length to create a "gutter" that disperses rainwater evenly instead of it just spilling off the roof. I used to use a solid profile that was the shape of the bracket to represent the product, but it never looked right. Making them as a railing makes it look right, it's just not the most user friendly or the easiest to load into other projects.
    10,518
    03:29 PM
    Yeah, i would do those as Face Based (non line based) families.
    2,658
    01:29 PM
    If a profile could have multiple loops, that would work as a fascia, I bet.
  1. Edge based family + schedule possible???
    By martian75 in forum Architecture and General Revit Questions
    Last Post: April 30th, 2016, 08:35 PM
  2. Locking the origin of a line based family in the host family
    By Karzan in forum Architecture - Family Creation
    Last Post: April 1st, 2015, 09:30 PM
  3. Line Based Family nested inside another line based family and arrayed
    By MadMatt in forum Architecture - Family Creation
    Last Post: January 6th, 2013, 05:29 PM
  4. Array a line based family inside another line based family
    Last Post: December 11th, 2012, 01:08 PM
  5. Line Based Family Help
    Last Post: February 1st, 2012, 12:04 AM
