Results 1 to 10 of 16
Thread: Help me to create this family
    April 17, 2017
    I am working in Qatar, Lives in India
    19
    02:16 PM
    Hello All,
    Any one Please help me to do the proper family in the above attached image.
    Thanks
    Deepu Devarajan
    3,068
    04:16 AM
    Upload what you've tried so far & someone can tell you what you've done wrong.
    No one here is just going to make it for you.
    April 17, 2017
    19
    02:16 PM
    Help me to do this Family
    Hello All,
    Any one Please help me to do the proper family in the above attached Revit file.
    Thanks
    Deepu Devarajan
    April 17, 2017
    19
    02:16 PM
    Please check the attached revit file in the first reply for more information.
    Thanks
    Deepu Devarajan
    August 19, 2011
    New Hampshire
    506
    05:16 AM
    Is it two quarters of a circle sitting 90 degrees from one another? All you need is two extrusions.
    December 20, 2010
    1,082
    05:16 AM
    You will make a new Generic model family, set your reference planes as needed to control the size, then label them(dimension with label), then create one quarter of the shape from one elevation view, align sketch to ref. planes, finish, repeat from side elevation, then use join geometry to make the two pieces one. give them a material parameter. save and load into project. you may want to check the box for work plane based so they will snap to the top of your wall.
    April 17, 2017
    19
    02:16 PM
    First of All Thank you so much for the help.
    Here i am attaching the family that i created, Please check the attached Revit file, at the corner the two quarter's are
    overlapping. Please give me a solution for this issue.
    Thank you
    Deepu Devarajan
    July 10, 2015
    Boise, Idaho
    733
    03:16 AM
    Use voids to cut the overlapping areas
    April 17, 2017
    19
    02:16 PM
    Thank you for responding the post.
    I tried the voids in this family, It will not give the results. When i use void cut the result will be a void space at the corner.
    Thanks
    Deepu devarajan
    1,376
    11:16 AM
    make 2 triangular voids, one to cut one side and one to cut the other. Making the voids will most likely have them cut both sides (because voids usually cut all the stuff in the family automatically) , so you will have to uncut each of the voids from one of the sides.
    Took your family and added the 2 voids:
  1. Why won't this Generic Model Adaptive family create form in a Mass Family?
    By viratmanchanda in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 28th, 2014, 02:22 PM
