Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Doubt
    June 26, 2018
    8
    04:22 PM
    Doubt
    a help,
    I would like to know if it is possible to create a window with a mirrored side and a normal one
    July 10, 2015
    Boise, Idaho
    738
    01:22 PM
    Do you mean like a one way mirror?
    June 26, 2018
    8
    04:22 PM
    so this would be my doubt how to make a glass this way as I put it before, and what would it be like to do that way that you commented?
    1,380
    09:22 PM
    You can make a material "one way glass" of course, but that's just so people know whats kind of glass is in there, but I assume you want to see it in renderings as well?
    Interesting question, I would like to see what the Revit guru's come up with for this.
    4,415
    08:22 PM
    (not a guru, and certainly not when it comes to viz.)
    I looked into this once before when investigating fritting options - playing with thinly modelled veneers of materials to try and dupe Revit (and at that time, an early version of Enscape) but even with a very fine cut-out mask (to the "mirror" backer) the rendering engines understandably struggled with a convincing output - and seeing as we were due a physical mockup, put the testing to bed.
    Coeur d Alene, ID
    4,853
    12:22 PM
    So I just modified a window...One side was glass and the other was a mirror.
    In the rendering the glass is on the left, mirror on the right.
    It's just a quick rendering on medium.
    1,380
    09:22 PM
    OK that works, but the OP is asking about one way glass I believe, so mirror on the front and normal glass on the back.
    So not left and right, but front and back.
    July 10, 2015
    Boise, Idaho
    738
    01:22 PM
    That is not possible. It will have to be two objects to get that effect. That's not a big deal, just keep the overall depth of the glazing the same.
    10,530
    02:22 PM
    It actually is possible, with a single item (and a since instance of paint). Because of the way "Materials" are mapped in Revit, if you make the actual material transparent, but paint one SURFACE of it with a mirror, from the front side it will be clear, and from the back, it will be mirrored.
    July 10, 2015
    Boise, Idaho
    738
    01:22 PM
    Yup, he's right. I didn't think about painting. It's not something I use unless absolutely forced to.
  1. Duct Hanger doubt
    By Lauft in forum MEP - Family Creation
    Last Post: September 27th, 2015, 03:52 AM
  2. Stair doubt
    Last Post: October 25th, 2014, 09:11 PM
  3. Printing doubt
    Last Post: February 5th, 2013, 09:04 PM
