Thread: ElementID=0
    4,415
    08:18 AM
    ElementID=0
    Having a play around with "Getting & Setting" parameters, specifically Phases and Design Options, so that we can reach at them with VG filters for our early concept work using Masses.
    But, I've happened upon a curiosity - at least with projects created using our template...
    Run a simple definition on a raw "no template" model file, one gets this:
    Run the same, slightly expanded definition (that queries the parameter of instances) in a model made using our template, and one gets this:
    Q1. Should I be concerned that the ElementID of my "Proposed" Phase is 0? I mean I guess something had to be... but... well...
    Q2. If there is technically no issue with ElementID=0 (?) then why does "Proposed" not come through with it from the [GetParamů] node - and only return "non-pointer" errors (with the [Element.Name] node) and so in-turn resists the push through into my custom SP <Phase>?
    If I create, merge and rename a new phase with my (current, ElementID=0 "Proposed" phase) I can get round all of this:
    ...I know this isn't preferred, but given our .rte has long been out of automatic-OOTB phase-alignment with others, it's no real biggy to break another egg now.
    But I wanted to throw it up for consideration/discussion.
    November 21, 2012
    London, United Kingdom
    612
    08:18 AM
    Q1: Technically no, there are elements that are single digits as you can see. No inherent risk here.
    Q2: Looks to be some form of bug this one - Assumption here is that you renamed an Existing phase? May have got caught up somewhere trying to reconcile itself.
    4,415
    08:18 AM
    Quote Originally Posted by amoursol View Post
    I imagined as much, it does just feel a little 1-in-a-million that I'd actually "found" element numero null (you'd think it a deeper, project-info. kinda thing)
    Yeah a long, long while back I juggled about and renamed the phases without much care for their "true", behind-the-scene, ID'entity - and have encountered some issues since with phase-alignments - but noting, and "fixing" the issue (so that it's now #6855539, LOL) has cleared up the (strange, in Dynamo) behaviour - so all now feels good. But I do sometimes wonder if there'd be a benefit to "defrag" the ElementIDs after years of accumulative counting.
    November 21, 2012
    612
    08:18 AM
    ElementIds do jump around a lot - which can cause confusion. For example, you can try the following code to check things out!
    Code:
    import clr
    clr.AddReference("RevitServices")
    import RevitServices
    from RevitServices.Persistence import DocumentManager
    clr.AddReference("RevitAPI")
    import Autodesk
    from Autodesk.Revit.DB import *
    doc = DocumentManager.Instance.CurrentDBDocument
    elementIds,eles = [ ],[]
    for n in range(10):
        try:
            elementIds.append(ElementId(n))
        except:
            pass
    for e in elementIds:
        try:
            eles.append(doc.GetElement(e))
        except:
            pass
    OUT = eles
    In the Revit Sample File (Architectural) it gives me this:
  1. How to retrieve elementid from current selected group from model
    By invention in forum Third party Add-Ins, API and R&D
    Last Post: December 12th, 2014, 10:00 AM
