Thread: How to cleanup 2 files with different startup locations?
    April 12, 2015
    63
    09:19 PM
    I have 2 revit files done by different people. I've changed the project base point and survey point to be the same figures and the rotation angle etc to be the same, but when I do copy and paste to current view, the things don't match. Then I read about Revit startup location, and discovered that one of the startup location was on the right side the other file's startup location is at the left side.
    My question is : beside using shared coordinates and publish the coordinates to link them, is there any chance that I can reset them properly so they match perfectly from origin to origin?
    Thanks in advance.
    Member HansLammerts's Avatar
    April 22, 2011
    475
    09:19 PM
    Where did you read about 'startup location'? (I thought that a fourth coordination setting was a joke)
    10,426
    04:19 PM
    It's not a fourth. The OP is referencing the "Relative Origin."
    And only way to reallign THOSE is to pick up one of the models and shove it. I don't recommend it.
    Leave it where it is, and use Shared Coordinates. What are you copying and pasting between models, anyway, out of curiosity?
    Aaron Maller
    Director
    Parallax Team, Inc.
    April 12, 2015
    63
    09:19 PM
    Thanks for confirming it. Aaron.
    Not sure what we might be copying yet. But i think maybe some connecting linkways, ramps and road path etc when one of the building finish construction next year.
    April 12, 2015
    63
    09:19 PM
    Quote Originally Posted by HansLammerts View Post
    https://knowledge.autodesk.com/suppo...-Location.html
  1. What Revit Wants: Cleanup and Move Revit Backup Files
    Last Post: November 1st, 2017, 05:15 AM
    Last Post: March 26th, 2016, 05:15 AM
  3. Replies: 1
    Last Post: December 2nd, 2015, 02:34 AM
  4. - REX startup failed:
    By Sushobhan in forum Architecture and General Revit Questions
    Last Post: July 23rd, 2015, 02:30 PM
  5. Script Error on Startup
    By Mel in forum Architecture and General Revit Questions
    Last Post: October 29th, 2012, 09:02 PM
