Thread: Interference Check by element
    June 10, 2015
    91
    09:48 AM
    Anyway you can run an interference check for clashes by element(s) without having to do the entire model?
    Eg. Check pipe against ducts and cable tray on Level 1 Zone 3.
    Tnaks
    Andy
    February 29, 2012
    65
    03:48 AM
    You can select the pipes and ducts then use Interference Check and use the 'selected elements' option.
    October 17, 2018
    08:48 AM
    Allo,
    Does interference check consider floating or totally unconnected pipes or ducts as a clash? or does it ignore them and automatically consider them work in progress?
  1. Interference Check
    Last Post: November 21st, 2016, 01:42 PM
  2. Interference Check Help
    By waikikigirl in forum MEP - General
    Last Post: October 16th, 2015, 06:22 AM
  3. Interference check
    Last Post: August 28th, 2015, 03:38 PM
