Thread: Baluster not cutting at 'Top Cut Angle' reference plane
    Junior Member theoryshaw's Avatar
    March 2, 2012
    Madison
    32
    02:08 PM
    Anyone have a clue why the baluster in the attached Revit file is not cutting to the top rail?
    Attached Thumbnails Attached Thumbnails 2018-05-07_14-05-16_Revit.png   2018-05-07_14-05-03_Revit.png   2018-05-07_14-06-40_Revit.png
    April 24, 2018
    34
    03:08 PM
    This might not be the greatest solution but it does work. What you'll want to do is in the properties of the baluster family, set your Top Angle = Slope Angle. You will need to set the Slope Angle to anything greater than 0 BEFORE you set the parameters equal to each other. I'm not sure why but family breaks at 0 degrees. I would then create another baluster type that stays at a 0 angle for the horizontal sections of the railing.
    March 2, 2012
    Madison
    32
    02:08 PM
    Thanks @Dr2430.
    Unfortunately setting the 'Top Angle' = 'Slope Angle' did not work, but applying the 'Slope Angle' parameter as a dimension constraint did work.
    Seems hacky, but i'll work with that.
    April 16, 2012
    03:08 AM
    uncheck post might fix the problem.
    January 12, 2011
    London, UK
    569
    08:08 PM
    Quote Originally Posted by theoryshaw View Post
    That is one ugly banister. Any contractor will VE that down to a much smaller member unless it is also holding up the stair
    3,013
    12:08 PM
    If you examine the stock balusters you'll find there is a void that does the cutting. Most likely yours is lacking that void or it doesn't cut your solid.
    April 24, 2018
    34
    03:08 PM
    Just had a second thought from past experiences, these families are much easier to work with (in my opinion) if you make them railing supports and not balusters.
    3,013
    12:08 PM
    Oh...sorry...the issue is "Post". The parameter in Family Types alters its behavior. Uncheck Post - reload the family and override parameter types. It should cut at the railing afterward.
  1. Reference plane
    By Rubyak in forum Tutorials, Tips & Tricks
    Last Post: August 8th, 2017, 05:03 PM
  2. Cut Plane Not Cutting Family Component
    By brandsema in forum Architecture and General Revit Questions
    Last Post: September 25th, 2016, 01:30 AM
  3. Reference Plane
    Last Post: June 21st, 2016, 01:57 PM
  4. Wishlist - Right-click on named reference plane, set as work plane.
    By ryntau in forum Architecture - Family Creation
    Last Post: September 22nd, 2015, 04:30 PM
  5. Baluster Railing - use Baluster Panel Family or Baluster Profile
    By trevorpan in forum Architecture - Family Creation
    Last Post: July 26th, 2014, 09:56 PM
