Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: Brick/Block Coursing Layout Family
    May 18, 2011
    Calgary, AB
    413
    01:25 PM
    Anyone have the brick/block coursing layout family they could share? Should be a UK family which we don't have loaded here.
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    08:25 PM
    Hi Chris,
    I've uploaded the horizontal and vertical coursing guide families that are installed with Revit's Metric dataset to my dropbox:
    Click Me
    If it helps, there are some PDF guide's in case you need any guidance on brick and blockwork which I've linked below:
    Blockwork (CMU):
    Pages 5-7 of the guide below will give you the technical information for both horizontal and vertical
    Click Me
    Brickwork:
    Simple 2 page guide that covers brickwork setting
    Click Me
    HTH
    6,233
    03:25 PM
    I don't know how consistent brick sizes are in Canada or the UK, but there is often an annoying amount of variation between manufacturers in the US in bricks that are supposed to be the same size, even coming down to which plant they come from. Shouldn't change your layout jig too much, but definitely something to be aware of through the design process.
    Attached Thumbnails Attached Thumbnails BeldenQueen.PNG   TriangleQueen.PNG   AcmeQueen.PNG
    December 11, 2013
    464
    08:25 PM
    The standard metric brick is 215x102.5x65mm and doesn't change size at all. There are of course natural variations due to the production process but there are acceptable tolerances which must be met. Manufacturers also have their own 'Special' bricks which can vary from manufacturer to manufacturer e.g. https://www.ibstock.com/wp-content/u...o-Specials.pdf
    May 18, 2011
    Calgary, AB
    413
    01:25 PM
    In Canada a standard modular brick size is 90x190x57 3 vertical courses = 200mm.
    Working on a project that decided roman was a good brick size to use. I didn't want to try and figure out all the maths needed... hence the layout tool, which seems to only be available in UK content.
    Appreciate the families. I'll adjust them to suit my needs.
    6,233
    03:25 PM
    Click Me
    how have I never seen those?!?!
    January 19, 2012
    335
    02:25 PM
    I've customized that family since when I started with my current firm that does nothing but custom Masonry designs....I've made a few improvements.
    10,517
    02:25 PM
    If youre going to build or edit those components to work with Imperial units, i recommend building it out of "two arrays." One array that is however many items you need to make an even dimension, and then a smaller array for the "remainder."
    For instance, Standard brick here is 3 courses = 8 inches. That comes out to 2 171/256" in Revit, but three bricks do NOT equal 8 inches... They grow by 1/256". Over the course of a tall building, that adds up. You can work around it with how you nest your components, and array them, if you dont mind doing some math.
    For that reason, i keep two versions: A Plan version (much simpler) and the Section Version. Both allow you to start with or without a joint. The section version works on the double array.
    Attached Thumbnails Attached Thumbnails 2018-05-03_14-18-06.png   2018-05-03_14-17-29.png
    2,658
    12:25 PM
    Another way to manage this is to allow the joints to contract and expand parametrically based on the overall length/height within some set predefined range.
    10,517
    02:25 PM
    Yuck. id lose my **** if someone did that here.
  1. Vertical Brick Coursing
    Last Post: September 10th, 2015, 02:21 AM
  2. Depict Brick Coursing
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: August 17th, 2015, 01:49 PM
  3. Best approach for Raked Brick Soldier Coursing
    By SuperDave in forum Architecture and General Revit Questions
    Last Post: June 20th, 2013, 01:49 PM
  4. modeling a brick wall ( brick by brick)
    Last Post: April 1st, 2013, 03:50 PM
