Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: What controls the view title line length?
    December 3, 2012
    Fernandina Beach, FL
    57
    03:39 PM
    In relation to dropping a view, what controls the length of the line? We don't like the line extending the full width of the view and find we are editing that for every view made. Nor do we like it left justified. I've not had any luck finding where this is directly controlled. Can you all guide me?
    6,233
    03:39 PM
    It is controlled by the extents of the view, although I don't know the technical specifics of what it references for the actual length. You can however constrain the title line to a reference plane in your family and control the length exactly. I have mine setup with several different sizes - 3",4",5",6" & 7" be default, but it's pretty easy to modify and add more if needed.
    December 3, 2012
    57
    03:39 PM
    Thank you Chad. Is there a default location relative to the view? I like that specifically sets the lengths. That eliminates all the different looks...much cleaner. IDK why didn't come up with that.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,534
    12:39 PM
    Quote Originally Posted by stevenpapke View Post
    cleaner? don't use the stupid line
    2,658
    12:39 PM
    Amen, brother!
    June 21, 2012
    Tours, France
    1,042
    09:39 PM
    Agreed , We are not using that Stupid line anymore! lol
    December 3, 2012
    57
    03:39 PM
    Post up a sample image, love to throw darts. Has anyone figured out how the software justifies the location of the view title? I understand, its the view of the view. Its left justified, I get that. When we have a long section or long elevation, the standard in this office is not to run the line the full width, but to move the view title to the center and shorten the length. Removed or not, the line....IDC...trying to understand if this is hard wired in the software or controllable by default.
    Dave Jones's Avatar
    4,534
    12:39 PM
    The line has nothing to do with the justification. View titles are justified to the bottom left of the view. The line, if you use it, follows the view title. I don’t like lower left justification so I move each title to the bottom center of what’s in the view. And I haven’t used the line in some years as it was always a PITA to get it where I wanted it and the correct (to me) length, as you have pointed out
    June 21, 2012
    Tours, France
    1,042
    09:39 PM
    ..... it was always a PITA to get it where I wanted it and the correct
    And don't forget about a rotated detail or view!! that's why we are not using that anymore!
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    297
    02:39 PM
    Another options is to uncheck Show Extension Line in the Viewports Type properties and underline the text in the View Title's label. Add spaces in the label's Prefix as desired to push the text away from the #. If you would like the line to extend past the text a bit add spaces with an empty Alt+Code at the end in the label's Suffix.
    The line will auto adjust to the text and no more fiddling with that PITA.
  1. View Title - line length
    Last Post: August 8th, 2017, 04:28 PM
  2. view title in one line
    By philsogood in forum Architecture and General Revit Questions
    Last Post: May 29th, 2017, 10:42 AM
  3. View Vort or View Title Extension line
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2013, 02:23 PM
  4. How to adjust the starting location of the line in the View Title
    Last Post: April 27th, 2012, 08:39 PM
