Thread: visibility parameter
    April 9, 2018
    09:16 PM
    Hello,
    can i control a formula by checking on the visibility from a parameter, but in a project ..
    so for example i want to change a distance from my family by checking on a parameter in a project instead of the other (normal) way..
    October 14, 2011
    Boston, MA
    222
    02:16 PM
    Welcome!
    Yes, you can control a formula using a 'Yes/No' parameter and a conditional statement using 'IF'
    (Conditional Statements Here: https://www.revitforum.org/tutorials...day-usage.html)
    This is just one method of doing this but I like to create a few parameters for each distance value, a yes/no parameter and finally the distance parameter which will move the reference plane in your family. It gets broken down like this
    Distance1Value = 0'-0"
    Distance2Value = 6'-6"
    ToggleDistance = Y/N
    Distance = IF(ToggleDistance, Distance1Value, Distance2Value)
    This is impying that when ToggleDistance is checked, your Distance parameter will be set to 0'-0" (Distance1Value) and when unchecked, 6'-6" (Distance2Value). It is also worth mentioning that you can skip over using parameters for each value and just include the lengths in the formula, like so. IF(ToggleDistance, 0'-0",6'-6")
    You can then find the 'ToggleDistance' Parameter in the project either as Type or Instance, whichever you choose.
    things get a bit tricky if you want to use more than two values but I hope this helped!
    April 9, 2018
    09:16 PM
    Thank you very much billiam.. this was what i needed.
  1. How to control YES/NO Visibility parameter
    By prjpro in forum Architecture - Family Creation
    Last Post: March 28th, 2018, 01:30 PM
  2. Giving a Connector a Yes/No visibility Parameter
    By matfloyd2008 in forum MEP - Family Creation
    Last Post: June 5th, 2016, 02:19 AM
  3. Visibility parameter used for calculation
    By Dbark89 in forum Structure - Family Creation
    Last Post: February 10th, 2015, 10:34 PM
  4. Yes/No visibility parameter per view?
    Last Post: January 26th, 2012, 06:56 PM
