Results 1 to 10 of 15
Thread: Family with several beams and columns
    April 7, 2018
    5
    06:06 AM
    I wonder if it is possible to create a family with several columns and beams and get the lenght and cut length for each of the nested family. I have made the nested family shared and can get the type and family namne, but only the length for the family not the length and cut lenght for each column and beam. I post a Picture of the family I want to create, it´s a framing of Wood for a window.
    4,408
    06:06 AM
    First off, Welcome to the forum Harnta!
    Yes - with some caveat.
    You will not be able to employ the (Revit) column, nor beam, family templates to first make these sub-children, as they are "specials" that enable certain behaviours once loaded into a project - you would however be able to build the components using the more generic, er generic model category family templates - which you could then switch to the column and/or beam categories, then load within a "parent" family - which itself could potentially be one of the "cleverer" category-specific family templates (say column, to exploit level-to-level control).
    BUT
    before doing that, you would also need to plan out your scheduling strategy - so that you can consider your parameter controls and associations. At the very least you will probably want your "children" families to be shared, to scheduled directly, rather than "through" the parent, but whether their sizes are controlled by the "parent" family (or not) will define how you approach instance/type parameter assignments.
    Has that made any sense?
    May 30, 2015
    204
    12:06 AM
    Alternatively, and with out much context, this may be a good use of Assemblies inside of Revit- it would allow you to gather all of the elements and not have to do as much forward assumptions of what will be needed. - A process to consider
    April 7, 2018
    5
    06:06 AM
    Thanks for your answer!
    Now it works, but I need to create a own shared parameter that will represent the lenght and cut length in schedule. I supose it is not possible to get the "real" length from beams and columns when you create them in a generic family template first, or am I doing anyting wrong?
    4,408
    06:06 AM
    Quote Originally Posted by Harnta View Post
    Not sure I understand where you're coming from, but inclined to answer the question as posed "yes of course it is!" but perhaps post up your .rfa so we might take a look?
    April 7, 2018
    5
    06:06 AM
    I post the column and beam I have created with genric model template, the problem I have is that I can´t get any length or cut length when loading them into Project and making Schedule. What have I done wrong?
    February 2, 2011
    Rotterdam
    30
    07:06 AM
    In de family are none shared parameters. You should them as absolute minimum. Have you thought about the material? Gool luck. I tried it also with steel. I did not get the changing of profiles right. With wood that is much more easy. (Only 3)
    April 7, 2018
    5
    06:06 AM
    They are shared, at least when I nested them. I have nested them in to a family, and can get the information I could not get earlier. The problem now is how I get the length and cut length from the ”children” family created in generic family template. The length dosen’t even appear if I am not putting it in parent family.
    4,408
    06:06 AM
    Quote Originally Posted by JWR View Post
    Until the wood comes in a different profile.
    To clarify (for Harnta): material (parameter) tieing is entirely possible, parent-to-child.
    February 2, 2011
    Rotterdam
    30
    07:06 AM
    That is correct shared but you did not use shared parameters. Look it up.
    Verstuurd vanaf mijn Moto G (4) met Tapatalk
  1. Cant load structural beams and columns..
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: January 29th, 2019, 12:22 AM
  2. draw I-steel-beams and columns
    By huyvu85 in forum Architecture and General Revit Questions
    Last Post: November 10th, 2014, 04:56 PM
  3. columns and beams not showing in section
    Last Post: May 4th, 2013, 09:53 PM
  4. Beams & columns
    Last Post: April 22nd, 2012, 08:10 PM
  5. OOTB Content for Beams/Columns
    By TheViking in forum Structure - General Questions
    Last Post: May 7th, 2011, 04:57 AM
