Results 1 to 10 of 13
Thread: The Trouble with Window Jambs & Opening Cuts
    October 14, 2011
    Boston, MA
    222
    02:59 PM
    I'm hoping the experts can help me out on this one -
    Here is an example of a typical window we use in our office.
Name:	opening sketch.PNG
    You can see that we draw the opening cut boundary along the outside edge of the jamb. The reason we do that is so a wall doesn't overlap the jamb in 3D and in section views. In some cases we would like to continue the wall finish over top of the jamb face but we haven't been able to find a good way to accomplish this (so far no luck using additional voids).
    Has anyone been able to find a way to do this?
    do most people even bother modeling the jamb in Window Families?
    Thanks!
    1,380
    09:59 PM
    Not a 100% sure what you mean, but this is what I have.
    I basically have 3 voids, one for each layer of the wall which I can adjust with parameter top, bottom, left and right if needed.
    If that is what you are looking for I can maybe help you a bit more.
    10,530
    02:59 PM
    Separate voids, as Robin mentioned. My exterior trim cuts the wall completely different than the windows do, and the Windows are different on the interior side and the exterior side. Voids, not openings.
    October 14, 2011
    Boston, MA
    222
    02:59 PM
    thanks for the quick replies. How did you get around this error when making an additional void in the host wall
Name:	Void Error.PNG
    October 14, 2011
    Boston, MA
    222
    02:59 PM
    or do you mean no openings at all?
    December 20, 2010
    1,083
    03:59 PM
    correct you can't have openings and voids. however you can nest in families(trim) that has voids into a window that uses an opening. But its most flexible to delete the opening and make your windows with voids. Note when you do that the void will try to cut all your geometry, so don't make the full opening right away so you can "un-cut" the geometry.
    1,380
    09:59 PM
    Quote Originally Posted by billiam View Post
    I have never come across a window or door where an opening worked for me, so yeah get rid of that right away and add a few voids.
    10,530
    02:59 PM
    I use a combination, since my Voids tend to be within Nested Families. So i have both.
    December 20, 2010
    1,083
    03:59 PM
    I'm finding face based voids that don't pass thru the entire wall assembly frequently cause the finish thickness to be displayed wrong(too fat) its like half the wall get the finish material instead of whatever the thickness in the wall aseembly is set to. Anyone know how to solve this?Click image for larger version.
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    08:59 PM
    Model the finish separately and join to the substrate wall perhaps?
  1. opening window parameters
    By Steve3373 in forum Architecture - Family Creation
    Last Post: February 26th, 2018, 12:07 PM
  2. Window opening on curved wall
    By robledojuan7 in forum Architecture and General Revit Questions
    Last Post: January 5th, 2017, 02:21 PM
  3. Window Family - Opening Break Constraints
    By LKeyser in forum Architecture - Family Creation
    Last Post: January 29th, 2014, 03:58 PM
  4. Delete a door or window from a wall but keep the opening?
    By tobiolo in forum Architecture and General Revit Questions
    Last Post: October 8th, 2013, 02:47 PM
  5. 'manage > materials' window trouble in RAC 2012
    By buildit in forum Architecture and General Revit Questions
    Last Post: March 9th, 2012, 03:27 AM
