Thread: Hide Webmember in Truss
    February 2, 2011
    Rotterdam
    30
    06:47 AM
    Is it possible to hide a web form a Truss I used visible parameter looks like does not work.
    I think trusses are very special and different that other families I work a lot with structural framing almost everything is then possible. Is there a solution.
    What I try to make is a truss with option on and off.
    July 20, 2011
    854
    09:47 PM
    right, creating visible parameters in truss won't populate to related webs/chords, looks like a bug to me or at least should be on wish-list FACTORY!
    workaround is to create "empty" framing (perhaps w/ only single line) and apply to webs in truss type properties, any better solution?
    4,408
    05:47 AM
    The web line or the web element?
    Former: The web line can be set to a sub-category (of trusses)
    Latter: the web elements become structural framing elements in-themselves, so you need to be hunting those out to hide.
    /caveat : it has been a very very long time since I messed around with trusses.
    July 20, 2011
    854
    09:47 PM
    i don't see that the web line can be set to a sub-category (of trusses), i mean in truss family or in project, probably i missed something here?
    the web line visibility in truss family won't affect visibility of web element so using "empty" web element is a little bit easy than hunting those out to hide
    November 17, 2011
    38
    12:47 AM
    Hi-
    You can turn of the visibility of truss webs in a particular view using visibility/graphics.
    Go to visibility/Graphics for the view, expand the "Structural Framing" category, and look for the Web" subcategory. If you uncheck the subcategory, the Truss webs will not appear in your view.
    Does this accomplish what you need it do, or is there some other nuance of your question I'm not understanding?
    Joe
    July 20, 2011
    854
    09:47 PM
    good solution, turn off web subcat in struc framing cat won't affect existing same struc framing as web! confused a bit at 1st as it's not under struc trusses cat, seems struc framing included pretty much everything under its subcats i.e. web, chord, girder, purlin, etc
  1. Help with custom truss
    By sleeknub in forum Structure - Family Creation
    Last Post: June 2nd, 2017, 05:19 PM
  2. Truss change
    By mhm in forum Architecture and General Revit Questions
    Last Post: December 19th, 2015, 10:32 PM
  3. Truss Issues
    By doni49 in forum Structure - Family Creation
    Last Post: July 10th, 2015, 07:40 PM
  4. HIde wall, columns hide as well?
    By Hilife in forum Architecture and General Revit Questions
    Last Post: May 17th, 2014, 06:43 AM
  5. Truss Family
    By MartinGT in forum Structure - Family Creation
    Last Post: October 28th, 2011, 07:07 PM
