Thread: Swapping door panels and panel mirrors itself
    May 18, 2011
    Calgary, AB
    413
    01:33 PM
    Nested doors, I swap out an AL panel for HM panel and the HM panel wants to mirror itself in the frame
    I must be aligning some incorrectly in the family but not sure what it is. AL panel was derived from the HM... other than glass, they are the same door.
    Any help would be appreciated.
    2,662
    12:33 PM
    Without looking, I'm going to guess that your panels have different Is Origin reference planes and/or their named Is Reference is reversed.
    May 18, 2011
    Calgary, AB
    413
    01:33 PM
    They're identical. I started with the solid panel, then saved as to create the glazed panel.
    For the time being, I added a centerline reference plane in both families, then re-aligned and locked in the parent family to make it work. It might still be flipping around but it's not moving now.
  1. Swapping out Curtain Panels
    By ryntau in forum Dynamo BIM
    Last Post: September 8th, 2017, 05:25 PM
  2. Combined window and door schedule using curtain panels
    By aaronsmith0707 in forum Architecture and General Revit Questions
    Last Post: May 31st, 2017, 07:44 PM
  3. Panel Schedule - One column for panels/boards
    By lrcbgc in forum MEP - General
    Last Post: May 15th, 2015, 02:59 PM
  4. Door Family: Can I have nested door panels with different driving parameters?
    By rpester in forum Architecture - Family Creation
    Last Post: October 28th, 2013, 05:04 PM
  5. Curten Panel Door
    By Hbjorg in forum Structure - Family Creation
    Last Post: October 5th, 2012, 04:39 PM
