Thread: Trouble with loading my door family
    December 20, 2017
    08:40 PM
    Hello to you all,
    I'm having some trouble with loading my door family into a project.
    In my door family, i have 4 types of doors (one closed, 3 with glass) within 1 doorframe.
    When i load the family into a project, there's only 1 door (for example the closed one) visible. Even if I select another door (one with glass), the visabilaty won't change.
    I don't know what i'm doing wrong and i can't find something on youtube or something like that.
    It's probably something in the properties but i can't figure it out..
    Please, can someone tell me what i'm doing wrong so i can fix it and have 1 family with 4 doortypes?
    (sorry for my english, it's not my native tongue)
    July 10, 2015
    Boise, Idaho
    738
    01:40 PM
    Are you using nested door panels or visibility parameters?
    4,415
    08:40 PM
    Welcome to the forum!
    We have an upload function, if you can share the .rfa we might take a look!
    December 20, 2017
    08:40 PM
    I'm using this .rfa file. It's in Dutch, i hope you can look at it.
    I'm looking everything through right now and i notice that i can only switch between the closed panel and just one door with glass. Eventhough all 4 door types are loaded into the family. I also linked the parameters from every door into this family.
    I've seen somewhere that you have to make some doors invisable, but i don't know how.
    June 21, 2012
    Tours, France
    1,044
    09:40 PM
    Hi swarchitecten, Probably not you want to hear but, I've looked into your family and (I'm Sorry) but is a mess , none of your parameters works properly, you have a lot of parameters and none of them seems to be rightfully mapped.
    First things first, you may need to re-draw your entire geometry but before that you need to check if the parameters work, how??, make things simplest as you can, first check if your reference planes are well constrained, secondly check if your parameters work with your reference planes, test different sizes in both views plan and section, then once those parameters work you'll need to add more parameters, if you want I've modeled some doors recently and I can help you if you give me enough information to be able to model that door, regards
    June 21, 2012
    Tours, France
    1,044
    09:40 PM
    Quote Originally Posted by swarchitecten View Post
    PTE_Vitré_Cadre_Métal_Bati_Fixe.rfa
    here this is one of my doors, I guess you may understand better things if you deconstruct my RFA file, regards
    By the way my RFA file is in french but I'm pretty sure you"ll understand how those parameters work , but if don't , please send me a message I'll explained you
    ahh, I've almost forgot that @Aaron Maller upload some great content this week you can learn a lot by working with it's files, this is the post https://www.revitforum.org/architect...tml#post196499
    December 20, 2017
    08:40 PM
    It's no problem, i've allready thought that maybe it's better to start a new one. I'm 'just' an intern so almost everything in Revit is new for me. Thanks for your reply though
  1. Trouble while importing a door family into a project
    By JLFN1964 in forum Architecture - Family Creation
    Last Post: November 24th, 2016, 11:06 PM
  2. Loading Family Error?
    Last Post: March 20th, 2015, 01:50 PM
  3. Loading of Diffuser family
    By zacoolm in forum MEP - General
    Last Post: April 22nd, 2013, 07:54 PM
  4. loading family
    Last Post: March 23rd, 2012, 04:03 PM
  5. In Trouble _ Loading 2D components
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: October 5th, 2011, 05:12 AM
