Thread: Obtuse vs Acute angles
    3,072
    01:58 PM
    I'm working on a Countertop family trying to get it to have an adjustable angle for the leg.
    I've uploaded a simplified version.
    If I change the angle of the leg from 120 to 60, it breaks.
    If I change the angle from 120 to 80 and then to 60, it works fine.
    So the problem is not in the geometry of the extrusion. It CAN create the geometry correctly. It just can't do it in one big jump.
    Huh? Is there anything I can change to allow a big change like that?
    I suspect the error happens when the inside corner rotates above the top edge.
    The leg is all hosted by a Reference Line & a bunch of other RLs based off that one.
    Perhaps because the change of the angle happens first; before the calculation of the other leg. (hardto explain)
    You can see how that happens if you let it break and Remove Constraints.
    But, as I said it only does that if you change the angle in one big jump.
    August 19, 2011
    New Hampshire
    506
    02:58 PM
    You hosted the extrusion to a reference line, that's why it doesn't like it. It works fine after changing the host.
    3,072
    01:58 PM
    What did you change the host to? And do you mean the Work Plane?
    I see that fixed it on my simplified version, but if I change the Work Plane to Reference Level in my full-featured family, it won't let me change the angle at all.
    July 10, 2015
    Boise, Idaho
    738
    12:58 PM
    I've had similar effects when my door swing exceeded 135 degrees. I was going to see if having the parameters start at 180 degrees and work backwards fixes this
    August 19, 2011
    New Hampshire
    506
    02:58 PM
    That's a different beast, Dave.
    Because you added the radius corners, it's better to split up the extrusion into different parts. One extrusion for the angle-adjusted portion, another for the unmoving section. The angle-adjusted portion will have its workplane hosted to one of the reference lines, the other to any other reference plane.
    3,013
    11:58 AM
    Quote Originally Posted by DaveP
    ...What did you change the host to?...
    I reassigned it to Ref Plane Counter Top. The point is that the Reference Lines are moving when what you really want is the solid to stay in place but alter some portion of the sketch. Hosting by a static reference plane eliminates that conflicting goals of altering the angle position of the reference line and the constraints of the sketch.
    3,072
    01:58 PM
    I don't suppose there's any good way to make two pieces without a joint?
  1. Baluster top and bottom cut angles
    Last Post: February 23rd, 2015, 03:30 AM
  2. Problems with locking to angles(?)
    By jeeenyuss in forum Architecture - Family Creation
    Last Post: April 2nd, 2014, 01:58 PM
  3. L shape stair with landing and acute angle
    By mgrarch in forum Architecture and General Revit Questions
    Last Post: May 4th, 2013, 01:18 AM
  4. Flexing families with angles
    By madhaka in forum Architecture - Family Creation
    Last Post: March 24th, 2012, 12:26 PM
